Question about Poljot Watches
I have a Strela watch with the 3133 movement. The stop watch second hand does not reset to 12:00 position. Instead, it resets to a couple of seconds negative (ie 58 seconds). What is involved in getting this to reset straight up. Thanks, Graham
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
  • 18 Answers
SOURCE: Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Posted on Jul 09, 2009
  • 56 Answers
SOURCE: The large second hand for use in the chrono mode
pull out the crown to either the 1st or 2nd position and use the top and bottom buttons to zero out. please rate my solution
Posted on Oct 10, 2009
Testimonial: "Thanks. Awesome correct solution in minutes and free!!"
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
  • 2501 Answers
SOURCE: My new Kenneth Cole kc3730 wristwatch when I use
If it is a new watch then have you still got the user manual?
I have seen some watch instructions detailing how to do want you want to do, so it might be a common problem.
If you cannot sort it out and have a Kenneth Cole dealer near you, then take it in and discuss it with them.
Their web site does not seem to have any instruction manuals for downloading , so I can't read the instructions for myself but if phone them on 1 800 KEN COLE (536-26530), then they may be able to help you.
Posted on Jan 23, 2010
Heuer chronograph second hands will not reset to 12 after I reset chronograph . It's a quartz watch with mechanical chronograph movement. Any one know how to do this, I know there's a way but I don't know...
Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 28, 2010 | Tag Heuer Watches
On a Invicta Men's Off-Shore Russian Diver Quartz Chronograph Silver-tone Watch, the big min hand does not stop at the 12 clock position but instead stops 2 mins before the 12. It stops on the 62 instead...
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Jan 12, 2010 | Invicta Off Shore Russian Diver Stainless...
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 11, 2010 | Guess Stainless Steel Chronograph Watch...
I can't figure out how to adjust the offset chronograph
This is to adjust the seconds hand or minutes hand for the chronograph. Pull the crown out either one click or two ... depending on the models. Squeeze and hold the top and bottom buttons at the same time (timer stop and reset buttons). Hold down together for 2+ seconds. The chronograph hands should reset by spinning around and stopping at 0. If the don't stop right at zero, you can now adjust where they stop. Leave the crown where it is in that same position out. Press the top chronograph button and hold it down for fast movement or short presses for fine movement to adjust til it stops at the top. This will adjust where the seconds hand stops. Then click the bottom chrono button once. Repeat what you did with the top chrono button and it should allow you to fine tune the position for the next dial, and so on. When you are done, press the crown back in all the way to the normal position.
May 21, 2009 | Invicta Dragon Lupah 2093 Wrist Watch
My stopwatch resets to the 7 instead of the 12. Can you help
On most watches all you have to do is pull the crown to position 2 (the last) and depress pusher A (on the top). The second hand should advance in 1 second intervals. Keep pushing the A pusher until the second hand lines up with 12 hour marker. Push the crown back in and your done!
Apr 11, 2009 | Oakley Detonator OAK0530 Wrist Watch
Rate me, please.
Mar 23, 2009 | Watches
How to zero the chrono second hand( doesn't reset to zero)
Paste this link into your browser, find your movement caliber number and download instructions how to reset your Citizen watch:
http://www.citizenwatch.com/COA/English/settings.asp
Do not forget to rate, please.
Jan 22, 2009 | Citizen Eco-Drive AT1000-50E Wrist Watch
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Watches Logo
159 people viewed this question
Top Poljot Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Poljot Watch Expert? Answer questions, earn points and help others
