Question about HP PSC 2210 All-In-One InkJet Printer
What is error (ox80210001) ? I get this error when I try to scan to the pc
2 Suggested Answers
  • 2973 Answers
SOURCE: I am unable to scan
Please follow the sequence below:
Unplug the device from the computer.
From Control Panel->Ad Remove Progs uninstall the device.
Reboot the computer.
Reinstall the device.
Plug in the device and allow Windows to auto detect the device and load its drivers.
Use the program provided by HP to scan.
And cheers.
Posted on Jul 07, 2011
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
Jun 09, 2014 | Canon Pixma MX452
Hp 3500C communication error
Restart the PC and the scanner and try again. Make sure you installed the right drivers, make sure that the PC see's the scanner, check devise MGR and look under printers, interface devise.
Apr 03, 2013 | HP ScanJet 3500C Flatbed Scanner
How to fix canon mp258 error code 2,140,2 when i scan douument
please help me....
I m trying to scan my document but it is showing error code 2,140,2 on PC and error code E5 at printer....my catridiges is empty is it because of that reason............
Aug 11, 2012 | Canon PIXMA Office Equipment & Supplies
I am unable to scan photos from my Hp psc2175 all in one ink jet printer from the printer to my HP windows xp computer "My pictures". I have uninstalled and reinstalled the printer to no...
And cheers.
Jul 07, 2011 | HP PSC 2210 All-In-One InkJet Printer
I have a kyocera cs-1650 and am trying to scan to PC. Error message: Destination PC Folder is Different-contact admin. Can you help?
scan yo pc use file scan uitility , make sure you install that program, configure it, it seems you did not configure the folder where the scan has to go, so you go this error.
Dec 29, 2009 | Kyocera Copystar CS-1820 Black and White...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Error Scanning from All-In-One to Vista
This appears to be a Vista driver software issue- check out Lexmark for any updates
You can also try the followng.
go to--- Start/Programs/Accessories/system Tools/Compatibility Wizard and try resetting the machine to run as XP
Jan 25, 2008 | Lexmark X9350 All-In-One InkJet Printer
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
PC Tools stops at DEEP SCAN When I'm trying to scan My computer system.
This is PC Tools Spyware Doctor program? Try booting the computer in Safe Mode (press F8 during the boot process before you see the Windows logo and select Safe Mode from this list of options) and then running the scan. With heavier infections many cleaning tools can be blocked or have inconsistent performance.
Dec 07, 2007 | Computers & Internet
HP PSC 2210 All-In-One InkJet Printer Logo
129 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
