Question about Kenmore 62622 Electric Dryer
Dryer stopped heating, put new element in and there is still no heat.
  • Kenmore Master
  • 2,295 Answers
Why did you put a new element in?first off you need to send the full model number when you ask for help.open the door and you'll see a tag with the model number,it's around the opening where you put the clothes in and it will start with 110.you need to unplug the dryer,with a meter read out the part that you think is bad,you have to remove at least one wire off of the part you're checking,put the leads from the meter onto the part and if you get a reading it's good,if it stays on 1 the part is bad,it's that simple.send the full model number and i can help you.
Posted on Apr 01, 2011
  • 209 Answers
SOURCE: Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
Posted on Sep 29, 2007
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 1122 Answers
SOURCE: Cabrio Electric Dryer Heating Element
have you checked the high temp thermostat?
Posted on Sep 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
My dryer stopped heating but still goes through the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Whirlpool LER5636P Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
Heat elament is out
  1. Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Unscrew the screws holding the element in place and pull it out.
  5. Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Sep 23, 2009 | Washing Machines
Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
Jul 22, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Jan 21, 2009 | Dryers
Replaced heating element in dryer. will not run.
You have a bad (thermal limiter). It's like a fuse one time shot, it stops all of the control power to the dryer. Try testing it with the dryer unplug use a ohm meter across the leads. It should read some type of a reading, if it reads OL it's burn out.
Jan 13, 2009 | Frigidaire GLER341A Electric Dryer
New Element, still no heat
Jan 07, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 62622 Electric Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
