I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port capabilities. Now I have a new MacBook which does not have a FireWire port so I can't get my back up info off it to transfer to my new Mac! Does the FireLite Smartdisk company have a cable I can use that has a FireWire plug on one end and a USB plug on the other? or an adapter?
  • 739 Answers
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Posted on Apr 01, 2011
Testimonial: "Thank you SO much! I really appreciate your help! aloha!"
  • hamster47 Apr 01, 2011
    Just in case,
    Look at this onehttp://www.usbnow.co.uk/Adapters_&_C...
    The drive inside the firelite might be an ide type therefor the links I gave earlier will not be appropriate.
Do I need a pwer cord for theis model or will it
Look at the connectors on the outside of the case.
If there is a socket for an AC adapter, then it requires one.
If there is no such socket, then none is required.
Jul 31, 2010 | SmartDisk FireLite 60 GB Hard Drive
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
Where did all my disc space go?
Empty your "Recycle Bin" -- it's possible that the files have just "moved" from their original location, and have _not_ really been "deleted".
Or, right-mouse click on "My Computer", and choose "Manage". Click through "Disk Management (local)", and you'll be able to "delete" the partition(s) on the drive, and then "create" a "new" partition, which, of course, will be 100% "empty".
May 07, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
It seems the new macbook pro does not support the firewire connector. Is there a different wire available? It looks like the macbook pro has a firewire connection but it is much smaller than the original...
The problem lies in your cable!
The new macbook pro still uses firewire and will be compatable with your drive. It just uses a 4-pin instead of a 6-pin connector. You can get an adapter or new cable that goes from 6 to 4-pins.
They did take away firewire from the new line of plain macbooks though (shakes fist at steve jobs)
Feb 07, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
Miising power supply
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Feb 27, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
Firelite hard drive won't mount on a Macbook
Sounds suspicious, have a look at other world computing, they have all sorts of work rounds for apple limitations. Have you looked in the disk utility to see if it is there? if so run repair and permissions.
Jan 25, 2009 | SmartDisk FireLite 80 GB Hard Drive
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
