Question about Panasonic Televison & Video
My panasonic cinemavision has wavy lines across the screen how can i fix this?
chrispurs1
  • 372 Answers
SOURCE: Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Posted on Sep 12, 2007
yambo
  • 230 Answers
SOURCE: Samsung HCN653W 65 has wavy vertical lines
I can help you,  call me 910-8936663
Posted on Oct 27, 2007
Slinteriors
  • 8617 Answers
SOURCE: Blue line across panasonic large screen hdtv
What is the model number of your set?
Posted on Jan 13, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 24, 2009
SD Tech
  • 14553 Answers
SOURCE: I have red lines going across tv. wavy lines also
This sounds like a convergence problem.
If model number is AV48WP30 go into the customer menu and select CONVERGENCE---if Red or Blue will not move in some direction one or both of the two STK-392-110 CHIPS this set uses for convergence is bad.
What happens is the convergence chips are black in color--about 2 1/2 inches wide X 1 1/2 inches tall with 18 pins each----the back of each is metal--when they are installed(each is mounted to a metal heatsink to keep it cool) they apply a white grease to transfer heat quickly----
After some years the grease dries out and one of the chips overheats and fails.
Not a real hard repair to do if you are handy and know how to solder----
Most shops are going to charge about 300 or more for this repair-----considering you can buy all the parts for under 25 dollars if you or someone you know can do it you can save a lot of money.
I can give you general instructions for this repair on this set.
I have repaired hundreds of sets with convergence troubles--very common problem.
Let me know if you have questions or need advice.
Regards, SD TECH
Posted on Oct 26, 2009
My 51" Panasonic CinemaVision rear-projection HDTV
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Wavy dark lines
Are the lines fine diagional across the screen and are they black in color.
Jan 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Screen is distorted and has wavy line across.
46" Samsung LCD, screen is distorted and has wavy lines across the screen.
Sep 26, 2008 | Samsung Televison & Video
Wavy lines across the digital screen of DSC-V1
Can u mail me 1 photo at welcomejee@yahoo.com to understand what exactly happening with your camera?
May 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sep 06, 2007 | Toshiba 32A60 32" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
