Question about Frigidaire Affinity ATF7000ES Front Load Washer
Have Frig Affinity Washer Front Load ATF8000FS1...Going thru all cycles fine, but stops spinning at the the final spin cycle. No error codes showing either. I tried to set just the spin cycle and all it does is the timer countdown in minutes...no spinning. Yet it is spinning during the wash cycle. Any info would be greatly appreciated. Dan Carey
  • 415 Answers
If there is water left in the tub area then the pump is plugged, but if no water then the problem is the door latch switch.
Posted on Apr 01, 2011
I have an Affinity washing machine that shows an E23 error code.
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
Sep 11, 2014 | Frigidaire ATF6000ES Front Load Washer
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
E47 and no spin cycle on ATF8000fs1
E47 error is for the door lock assembly. Here is the part to order.
Here is a video to show you how to make the repair.
Dec 06, 2012 | Washing Machines
I have a frigidaire front-loading Affinity model #atf8000fs1 washer with the stack kit placing the dryer on top. During the spin cycle, it dances frantically and when I canceled the cycle and opened the...
Go to www.repairclinic.com and enter atf8000fs1. You will see a list of common replacement parts (including the gasket) and may be able to view a generic Frigidaire video showing disassembly.
Apr 16, 2017 | Frigidaire ATF6000ES Front Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer will drain but will not reach full spin in spin only mode
they dont spin full speed if they are overloaded, try it with less clothes.
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
525 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
