Question about Toshiba Computers & Internet
Drive door stuck. paper clip will not work to open
    Genius:
  • 1,288 Answers
You don't mention which model this is..so this is a generic solution
Best solution. If you can't get the CD tro eject by the paperclip method, or by trying to eject using the DVD drive icon in my computer try this:
Under the laptop, locate the screw that holds the DVD drive in place and gently ease the dvd drive out of the laptop body. (If you are unlucky, it may be locate under the keyboard, in which case,you will need to remove the keyboard).
Once out, at the sides of the DVD drive, there are 2 small plastic clips that need to be gently pushed inwards, this will release the front cover plate. Once this is removed, you should be able to get access to the drive and ease out the CD by pressing the contact that releases the tray
Check the operartion of the tray, if it is rough or notchy and does not go back smoothly,. you may need to replace the drive
Posted on Apr 01, 2011
HOW DO I OPEN THE CD DRIVE
Hello. The stuck cd drive door. Bin there before. Use a paper clip, bend out one of the arms of the paper clip. Look for a tinny sized pin hole on the cd drive door. Use the paper clip as a push key. Put the paper clip leg in to the hole, lightly push in and pull the cd drive door lightly toward you. Then you can take out the cd and push to closed the door. Then you can use the computer as before. But remember to keep the paper clip as your emergency key. Good Luck.
Jun 03, 2014 | Packard Bell Computers & Internet
DVD stuck in my Yamaha DVD-c6761 DVD/CD player. How do I get it out so my player will open and work properly again.
Unbend a paper clip.Look very closely at the area around the CD/DVD drive door until you find a really small hole - it almost looks like an accident (probably just below the door). Insert the paper clip in the hole (don't be afraid). Push the paper clip gently to press the spring-loaded latch.Your CD/DVD tray should open right up. That's it. Deals Prices
Jan 10, 2014 | Audio Players & Recorders
How do I remove the back of my Gateway ZX6971-UR30P. I have a cd stuck in the disc drive and the door won't open.
Have you tried to use a straightened out paper clip to eject the disc. You should see a small hole next to the eject button on the disc drive, just push the paper clip in that and the drive door should open.
Sep 11, 2013 | Gateway ZX6971-UR30P 23-Inch All-in-One...
Cd door is stuck
If you cannot open it with the button on the door, start the computer and click on the start button, select COMPUTER, it should show the drives that are on the computer, Right click on the cd drive and a menu comes up that has the option to EJECT. See if that works. If it does not, there is a small pin hole in the door slot that you can stick a paper clip in that you bent to fit in the hole. Press the paper clip into the slot till the drive door opens. If you have to do that then you should replace the drive.
Feb 02, 2013 | HP G62144DX Laptop
How to eject cd from dell inspiron
Press the button the cd drive door or click Start/My Computer then Right Click on the CD Drive and select EJECT.
If it is stuck you will need to take a Paper Clip (Gem Clip) and straighten it out. Then look for the tiny hole on the CD Drive door and push the Paper Clip (Gem Clip) into the hole and Press the the button on the drive door. As you Press the button on the drive door, push the paper clip in and the door will pop open.
Don't worry about breaking something, that is why the tiny hole is there.
May 04, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
How do you eject a stuck disk
Well you may start by turning the computer off. Get a paper clip and straighten the long leg. Look closely at the front of the CD drive, you should find a hole that's about the right size for the paper clip.
Carefully push the paper clip straight into the hole to release the catch. The drive door should open without too much pressure. If this doesn't work, the drive may be physically jammed shut. In that condition you need a hardware technician to fix it.
Good Luck!!
Thanks for using FixYa!!
Dec 02, 2010 | Toshiba Computers & Internet
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
Cd stuck
Take a paper clip and unravel it. Insert the paper clip into the small hole located on your CD player. The tray should eject.
Aug 04, 2008 | HP Pavilion zd8000 Notebook
C d door stuck
you can find a small hole at the front side of your cd drive , carefully insert any pin inside this hole and press it , your cd drive door will open.
Some time holding the cpu in 90 degree angle while system is on and pressing the eject button releases the cd door.
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
