Refrigerators Logo
Posted on Apr 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drips of water have frozen inside top of freezer area. Why and how fix?
fixrguy
Level 3:
  • Master 415 Answers
  • Posted on Apr 01, 2011
fixrguy
Master
Level 3:
Answers
415
Questions
0
Helped
82576
Points
1311
It sounds like the gasket on the one or both or the door has a gap, when you find it get you hairdryer out and don't put direct heat on the gasket sweep it back and forth until it seals against the shell for the frig lining.
Jenn air refrigerator model JS48CSDWDA defrost drain freeze
How to fix a leaking refrigerator - frozen defrost drain tube ...
? 1:39
www.youtube.com/watch?v=_ycWz_U_GDU
Aug 14, 2010 - Uploaded by justenuf2b How to fix a leaking refrigerator by unclogging a frozen defrost drain tube for refrigerator. I had not intended
1helpful
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Water drips from the top back part of refridgerator - we have a top freezer
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Water drips inside the refrigerator
That usually means your drain in the freezer is clogged or frozen. You will have to take the evaporator cover off to see the drain hole at the bottom in the middle. If it is covered with ice remove the ice by letting it thaw for a couple of hours unplugged and door open. Should be able to remove excess by hand.
1helpful
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
8helpful
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Water puddles on the bottom inside of my freezer and freezes.
Your drain is clogged. Remove the shelves and see if you can clear it with a stiff wire. It is located at the bottom rear. It may be frozen; in that case pouring very hot water or a using hair dryer (be careful not to melt anything!) should clear it enough to run a wire through it.
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
2helpful
Kssp42qhwoo(7 yrs old)
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
