Question about Nikon FE 35mm SLR Camera
Which battery does the Nikon FE take? - Nikon FE 35mm SLR Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You've got some choice here. You can use two 1.5V A76 or 357 batteries, or one 3V 2L76 battery.
Posted on Apr 01, 2011
    Scholar:
  • 48 Answers
The best choice is silver oxide because it has a flat discharge curve until exhausted. Alkaline and lithium alternatives have declining voltages before they are dead, so you can get inaccurate readings.
Some common manufacturer designations for the correct size are: 76, S76, 357, SR44. The FE takes two of these. There are other equivalents, just be sure the packaging says silver-oxide.
Posted on Oct 19, 2013
When was my nikon fe made?
Nikon produced the FE from 1978 to 1983.
If you're asking when a particular FE was made, you'll have to provide the serial number.
May 09, 2014 | Nikon FE 35mm Film Camera
I have a nikon fe shutter jam
Turn the speed dial to M90, This will reset the camera, Then make sure you have good batteires before you tke it off of M-90, Battery check on side of camera,. Top cover rewind side
Sep 25, 2013 | Nikon FE 35mm SLR Camera
Nikon fe 35mm slr camera
The FE takes two LR76 batteries or equivalent.
Nov 30, 2012 | Nikon FE 35mm SLR Camera
Nikon Fe meter - warm batteries
If the batteries discharged sufficiently to become very warm in just a few seconds then there's an internal short circuit and the internal circuitry has almost certainly been fried beyond repair. To get warm so fast, those batteries will have shoved some significant current through circuitry designed to handle mere milliamps.
Your camera will be repairable using donor spares, but the repair will cost more than buying another fully functional FE especially when you add on the costs of the CLA (Clean, Lubricate, Adjust) service that it will almost certainly need and the likely need for foam light seal replacement. If you buy another FE it will also most likely need a CLA and seal replacement unless there's proof of it being recently done, but at least you won't have the additional costs of buying a donor FE, stripping it for parts and then doing a heart transplant on it.
On balance, yours is best used as a spares donor; you'll get some of what you spent back if you sell it as a spares/repairs example.
Sorry there's no fix, but I hope that you have still found my reply to be of some use. If so, please rate my answer.
Feb 22, 2010 | Nikon FE 35mm SLR Camera
Chronic sticking shutter on older Nikon
If the shutter doesn't stick on the M90 position, the problem is electronic. If it does, the issue is mechanical. Try the battery check. Hold it for a few seconds. If the LED goes out, the issue is most likely with the batteries. Use really fresh, top quality batteries. Use only silver oxide batteries, not the alkalines that are often substituted.
Mar 19, 2009 | Nikon FE 35mm SLR Camera
Nikon FE shutter speeds problem
I don't know, but it's worth a try. I took mine to the camera store, because my shutter wouldn't even work anymore, even with fresh batteries in it. He again tried new batteries, and turned the shutter speed knob from Automatic all the way over to "B" for Bulb, and back to the Auto. Guess What! I haven't used the camera in 3-5 years because I thought it was broke and going to need factory repair. Well, this tricked worked for me. I was so thrilled, because my daughter wanted some double exposures and special filters shots for her wedding. Also the weight of the camera I couldn't handle anymore with a health problem, so I went to digital, but would love a Nikon good digital.
Good Luck!
May 13, 2008 | Nikon FE 35mm SLR Camera
Nikon FE
TRy firing the camera in the M90 setting. If it fires properly, use the battery test switch. If the battery LED doesn't light up, replace the batteries (2 MS76 type). The FE requires healthy batteries to operate the shutter. If the meter is calling for a slow shutter speed (low light or lens cap still on?). If the batteries are good, but the shutter still won't fire normally in sufficient light, looks like you're in for a repair shop visit.
Feb 11, 2008 | Nikon FE 35mm SLR Camera
Loading batteries
Most Nikon manual focus cameras I see have the same battery chamber, and their battery loading procedure are exactly the same. Use a coin to unscrew the battery chamber at the buttom, the batteries should be instered into the battery holder (the unscrewed part) , with negative end goes in first. Also refer to the battery insertion direction on the side of the plastic part of the battery holder you will find it :)
Dec 21, 2007 | Nikon FE 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
140 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
