Question about Electrolux Microwave Ovens
I have a built in AEG/Electrolux microwave/convection oven (product No 944270628). I heat up a mug of milk each evening on full power, sometimes it heats up fine in 2.5mins, other times it will be luke warm & will need several more blasts to get it hot enough. This has developed from the milk staying stone cold after the allotted time but it would always heat up properly at the second attempt.
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
SOURCE: Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Posted on Dec 12, 2007
  • 9098 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
Posted on Jul 01, 2008
  • 9098 Answers
SOURCE: KitchenAid Superba combination built-in oven
It sounds like a stuck relay or other controller problem.
I don't have the service data on this one, but there should be a schematic or tech sheet / mini-manual either on the back side, behind the controls, or somewhere else inside.
If you or someone you know can locate them and scan and e-mail or copy & fax them to me, I can probably give you further guidance.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
  • 52 Answers
SOURCE: Microwave oven not heating
Return from store that it was purchased from. it is unfit for purpose
Posted on Feb 21, 2009
How to replace the magnetron on a em30mo65gssa convection microwave oven?
If you're sure the Magneton is bad, it's quite easy to remove and replace.
Dec 27, 2017 | Microwave Ovens
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
Sep 24, 2014 | Kenmore Microwave Ovens
Does not heat everything else works ge microwave oven JNM1851SMSS
It will be one of three things, magnetron, "heats food" high voltage diode,"sometimes cracks" or the high voltage capacitor, "usually shorts"
Mar 23, 2012 | General Electric JNM1851 1100 Watts...
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
My microwave stopped working suddenly, the fuse is ok, power supply ok. It is built in can you advise please.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
May 16, 2011 | Electrolux EMS2487X Convection Microwave...
Microwave Heating Handle more than Contents
This is because the mugs are not really microwave safe.
For a while they will work, but over time, some non-safe materials' characteristics can change with repeated heating.
Eventually someone will get a burn, and/or a mug will mildly explode into a few pieces.
I have personal and professional experience with this! *grin*
Aug 18, 2008 | Microwave Ovens
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
