Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
NO ICE IN FREEZER--ARM IS DOWN AND WATER SUPPLY IS ON.
  • 415 Answers
Can be any of the following faulty ice maker, faulty water fill valve(it has 2 valve one for the front disp and one for the ice maker) or a frozen water line from or to the filter assembly.
Posted on Apr 01, 2011
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Icemaker not working
In order to keep your refrigerator's ice maker working properly, there are some components that will require routine maintenance and inspection. Some of the most common problems that can occur with your ice maker are the ice maker not making any ice, making too much ice and not shutting off, the ice tasting bad, ice cubes too small or discolored and ice cubes not ejecting from the ice maker. Checking your ice maker for potential problems on a regular basis will keep it operating efficiently.
1.Inspect the water supply line for any signs of cracking or crimps in the line. A pinched water supply line can keep the water from getting to the ice maker, resulting in no ice or smaller than desired ice cubes. Check to verify that the water supply valve is open enough to provide an adequate supply of water to the ice maker.
2. Flush out the water supply lines if you are noticing a bad taste in the ice cubes. This can be done by disconnecting the lines and running hot water through them. Turn on the hot water at the kitchen sink and place one end of the water supply line near the tap, holding it in place to allow hot water to run through it. Place the other end of the supply line in the sink to allow the water to drain through.
3 Reattach the water supply lines to the water supply and refrigerator. Repeat step 2 for the water inlet hose which runs from the inlet valve to the ice maker. If the water supply lines are old or discolored, consider replacing them with new water supply lines.
4 Check the temperature in your freezer to verify that it is getting cold enough. The freezer's temperature should be at 5 degrees and can be set with a control dial, normally located in the refrigerator compartment of your appliance. To test the freezer's temperature, place a cup of cooking oil in the freezer with a cooking thermometer sitting in the cooking oil. Allow the oil to sit in the freezer for 2 hours and then check the temperature.
5 Check the ice maker's shutoff arm to verify that it is operating properly. To work normally, the shutoff arm should be in the lowered position. Inspect the arm for anything blocking it or preventing the arm from moving freely. Lift the arm up to see if the unit shuts off in the up position.
6 Unplug the refrigerator from the electrical outlet and remove the faceplate of the ice maker's shutoff switch with a screwdriver, located on the ice maker. Remove the entire ice maker unit from the freezer by undoing the screws that are holding it in place. Unplug the ice maker from the freezer and take it out of the freezer to work on.
7 Remove the mounting plate on the top of the ice maker by unscrewing the screws and lifting it off the unit. Locate the shutoff switch, which has three electrical wires attached to it. The shutoff switch is located directly under the shutoff arm of the ice maker. Pull the electrical wires off of the shutoff switch with needle-nose pliers and label them so you know how to put them back correctly.
8 Inspect the electrical terminals for any rust or corrosion. Use an electrical testing meter to verify that the shutoff switch is working properly. You should get a reading of 0 or infinity on the meter. If the shutoff switch is not giving a reading, replace it with a new switch and reattach the electrical wires to the switch.
9 Place the mounting plate back over the ice maker and attach it with screws, then reattach the entire ice maker unit to the freezer. Plug the ice maker wiring back into the freezer and put the face plate back over the front of the ice maker.
10 Plug the refrigerator back into the electrical outlet and allow the refrigerator to run for a couple hours. Inspect the ice maker to verify that it is working properly.
Hope this tips would help you.
Good day! : )
Sep 06, 2011 | Refrigerators
The ice maker is not making any ice
Hi rlh2004,
There are several factors why a refrigerator tops making ice. We will look on the most common factors and give you some troubleshooting that you can do to fix the issue.Before doing any checking or repair please unplug the refrigerator, remember your safety.
1. Check the shut-off arm - An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
The arm is supported at one or both ends. One end extends into the back of the front support. If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place. To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
2. Check the water supply line - The water supply line connects to a supply valve usually found under the kitchen sink or behind the freezer. If the valve is not turned to a position which allows for enough pressure, the water may not fill the ice mold.
Check that the water valve is opened to allow enough water to fill the ice mold. You can open the valve all the way but it is better if you open it just enough to provide the adequate pressure level.
You can also inspect the water supply line for dents or pinching that might restrict the flow of water to the icemaker.
3. Check the freezer temperature - The ideal temperature for the freezer is about 5 degrees (F). The refrigerator should be kept at about 36 degrees (F). The temperature can be adjusted using the controls found inside the freezer or refrigerator.
Hope it helps.
Thank you for using Fixya.
May 03, 2011 | Jenn-Air JFC2087HRS Side by Side...
I just hooked up the ice maker to the water line and put the lever down on the icemaker. The water has not filled the ice maker. Is there something I need to do further? The model # is 596.765 73600
  • here are some things to check for, please be very careful and only to this if you disconnect the power supply.
  • 1 Inspect the shut off arm located on the side of the ice maker. This arm should move up and down with a slight resistance when pushing upward. Make sure that this lever is not frozen to the side of the ice maker preventing it from dispensing ice. In addition, if the arm move loosely up and down, then it is broken and must be replaced.
  • 2 Verify that the ice maker is receiving water. Check the water supply valve which is usually located either behind the refrigerator or under the kitchen sink. The knob should be turned all the way clockwise until it will no longer move.
  • 3 Move the freezer or refrigerator out from the wall and locate the water supply line. This line extends from the water supply valve that was previously located. Make sure there are no kinks or twists in the water supply line as this prevents the ice maker from getting water. Also check for leaks along the supply line which will also prevent the ice maker form working.
  • 4 Locate the manual shut off button for the freezer, if it has one. In some models, the shut off button is located inside the freezer door. If this is the case, simply check to make sure the button is switched to the "on" position. Shut off valves are only on some Kenmore refrigerator/freezer combination appliances.
  • 5 Measure the temperature in the freezer by placing a thermometer inside and allowing it to sit for approximately one hour. If the temperature is higher than 17 degrees F, then something is wrong with the main freezer and not the ice maker.
  • 6 Check the water inlet valve to ensure that is allows water to flow through freely. First turn off the water supply at the water supply valve, usually located under the sink or behind the appliance. Locate the water inlet valve by following the water supply line up to where it attaches to the refrigerator or freezer. Turn the plastic nut at the base of the supply line counterclockwise to detach the supply line. Pull the two or four wires of the water inlet valve off of the terminals. Inspect the wires for burn marks or corrosion. If these are present, it means they must be replaced as water is not being fed to the freezer.
  • good luck
    Iain
    May 02, 2011 | Kenmore Refrigerators
    Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
    Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
    Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
    The Ice maker has stopped working.
    There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
    Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
    If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
    Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
    Ice maker shooting water along wall of freezer
    Hi...
    You need to check this
    Regards
    PCmania
    Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
    The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
    Hello jitkagardner,
    Welcome
    You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
    How old is the fridge?
    When have you last changed the water filter.
    Should be down below at the front grille!
    Try these tasks!
    If the ice maker is not producing ice or not enough ice
    Refrigerator connected to a water supply and the supply
    shutoff valve turned on? Connect refrigerator to water
    supply and turn water shutoff valve fully open.
    • Kink in the water source line? A kink in the line can reduce
    water flow. Straighten the water source line.
    • Ice maker turned on? Make sure wire shutoff arm or switch
    (depending on model) is in the ON position.
    • New installation? Wait 24 hours after ice maker installation
    for ice production to begin. Wait 72 hours for full ice
    production.
    • Freezer door closed completely? Firmly close the freezer
    compartment door. If the freezer compartment door will not
    close all the way, see "The doors will not close completely."
    • Large amount of ice recently removed? Allow 24 hours for
    ice maker to produce more ice.
    • Ice cube jammed in the ice maker ejector arm?
    Remove ice from the ejector arm with a plastic utensil.
    • Water filter installed on the refrigerator? Remove filter and
    operate ice maker. If ice volume improves, then the filter may
    be clogged or incorrectly installed. Replace filter or reinstall it
    correctly.
    • Reverse osmosis water filtration system connected to
    your cold water supply? This can decrease water pressure.
    Let me know how it goes!
    Huuum
    Please remember to leave a rating!
    Oct 21, 2008 | Refrigerators
    Ice maker not working
    ONE OF THREE THINGS,THE INLET WATER VALVE ON THE BACK BOTTOM HAS FAILED,THE WATER SUPPLY TUBE IN FREEZER BEHIND ICEMAKER HAS FROZE,OR THE ICEMAKER ITSELF IS BAD,LET ME KNOW WHAT YOU FIND-MIKE
    Jun 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
    Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
    95 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Sal De
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
