Question about Zebra Stripe S600 Thermal Label Printer
Zebra S600 When trying to print double 40x45mm labels it spools about 6 double labels then prints and then spool another 6 double labels. The paper/ribbon orange light then comes on.
Mmmm a-Jamone
Posted on Aug 05, 2008
The ink is not rolling back on the second roller once the label has printed.
First make sure that the Take up Spool is properly installed in the printer. There are "Notches" in the take up spool that need to mess to drive the Take up spool.
Next, make sure that you have the printer set up for THERMAL TRANSFER and not DIRECT THERMAL if your using a printer driver or label printing program.
Good Luck
mikeo@acebarcode.com
Feb 21, 2011 | Zebra TLP 2844-Z Thermal Label Printer
I CANT LOAD THE RIBBON AND LABELS AND THE PRINTER DOESNT RESPOND
It does look a little strange inside, but here's the manual:
http://tinyurl.com/yb2rpd4
Loading the Media, p 12
Loading the Ribbon, p 17
Be sure the ribbon comes off the spool clockwise, and the labels come off the spool counterclockwise. Look carefully at the pictures in the manual and you should be able to load it ok.
Also be sure to close the printhead (the purple handle that holds down the ribbon and labels) to the 6:00 position when you're done. Then close the covers, turn it on and try it out.
Hope this helps you! If so, please leave a rating.
Mar 15, 2010 | Zebra Stripe S600 Thermal Label Printer
How do you clear the printer buffer on a zebra 140Xi111 plus
1. click on "start" select "run" and type "services.msc"
2. after open services windows select "print spooler" services
3. stop "print spooler" services
4. click on "start" select "run" and type "C:\WINDOWS\system32\spool\printers"
5. after open the printers folder deleted all the pending print jobs
6. restart the "print spooler" services and try to print now.
Aug 06, 2009 | Zebra 140XiIII Plus Thermal Label Printer
My Zebra LP-2844-Z won't print, says spooling, printing, deleting
try this--open the control panel then open system & maint then admin tools. open services then find the print spooler svc and right click then restart. close all jobs and print windows first then try again
May 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Delay between labels
download the manual from zebras website im sure its not that complex to adjust it. www.zebra.com
Aug 16, 2017 | Zebra Z4Mplus Label Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
How do you load the spool of labels, can I see a diagram?
is so easy!!
you have a pumnal,ok?
do pumnal in this electronic
seorsy,is so god
is functionli naw
now?
Jan 03, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra s600
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
Nov 21, 2007 | Zebra Stripe S600 Thermal Label Printer
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Zebra Stripe S600 Thermal Label Printer Logo
174 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
