Question about Sunbeam Health & Beauty
I have a sunbeam "Mist-stick"
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Posted on May 30, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: Need parts for Sunbeam ultrasonic
I see you have been waiting on a response for some time and I suggest you contact Sunbeam (if you haven't done it already) at their website for Canada:
Sunbeam Canada Customer Service
konzzz
  • 255 Answers
SOURCE: Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
Posted on May 29, 2009
SOURCE: Just purchased a Holmes Hm495
Fill the tank up with cold water and turn up the volume control. Look for a clogged up nozzle on mister. Click on the link below to download and view the Holmes HM495C-UC user guide:
http://www.holmesproducts.com/ProductDetails.aspx?pid=1443
Posted on Oct 27, 2010
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
How can i gett my hair curly with no heat?
You can use curlers for that and manually curls your hair.
Nov 14, 2014 | Health & Beauty
Need instructions on how to use product!
the glove is a heat protective styling glove so you can touch your hair without burning your hand. It is pretty easy to burn yourself because it is so hot. try watching the TiGi videos on YouTube. For a more wavy look I keep my hair around the curler for a couple of seconds and then I run my fingers through.
May 01, 2013 | Helen Of Troy TIGI Bed Head Curli Pops...
Anyone got good advice how I can avoid getting a hair iron burn?
Here's a tip that I find really helpful - stick a thin plastic comb between your scalp and the curling iron. It will stop the iron from getting too close to the scalp.
Feb 20, 2013 | Health & Beauty
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
May 29, 2009 | Sunbeam Steam Master 4055 Iron
Health & Beauty Logo
95 people viewed this question
Top Sunbeam Health & Beauty Experts
musquodoboit
musquodoboit
Level 1 Expert
Steve P
Steve P
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
