Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp 37" tv flat pannel
  • 11,361 Answers
It is blinking because it sensing shorted circuits that are drawing too much current so it goes into safety shutdown mode, the shorts will more likely to be in the inverter board which draws the most power from the power supply module, try disconnecting the power cables to the inverter board to see if the TV will come on without the pictures but still has sound.
Learn more how to Troubleshoot LCD TV here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 01, 2011
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
Sharp tv remote control problem
Keep your mobile camera on press any key from remote you will get flash light in mobile.It means remote is ok.
Press On/Off switch from LED Tv and checked tv is on or off.
If Green light is blinking but tv not getting on follow as per attached file.
Mar 31, 2015 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Philips lcd tv dont turn on, blinking green light
Just fixed that exact problem on mine and made a video on what part and how to replace it. I also added a link below for the part I bought. L5973D STMicroelectronics Mouser
Oct 04, 2012 | Philips 37MF321D 37 in. LCD Television
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Green power light blinks, tv won't turn on more than a couple seconds after do volume up, channel down reset
Tv is going into fault protection. Bad Caps on the PSB-Power supply board
Best regards and Semper Fi
Aug 03, 2010 | Sharp LC37SB24U 37 in. LCD TV
Brand new Sharp Aquous 37". I turned the tv on and a blinking green light comes and goes. I tried to turn it off and the blinking green light still on and no picture and no audio.
Behind your TV, there should be a system reset button.
If this doesn't fix the problem, most of the time this means a part has failed inside the TV. I would use the warranty and take it back and exchange it. You shouldn't be having this problem right out of the box.
I would have them check the new one so you don't have to waste a trip.
Good Luck
Feb 20, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sharp 37 inch aqous tv power button blinking red
If the blinking light seems to be blinking in a pattern, then it is an error code. The end result in any case, is the main power supply is not functioning properly, or the backlight power supply has a problem.
Nov 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
320 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
