Question about Samsung DV448AEE Electric Dryer
Samsung electric dryer dv2c6bew/xaa power comes on when you hit start but nothing happens
  • cgottfredsen Apr 01, 2011
    belt is not broken
    belt is stiil on properly when i hit start the chdlock light is coming on either
  • Samsung Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description and my experience, I'd say possibly the belt has come off, thus activating the "kill switch".
I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
samsung electric dryer dv2c6bew/xaa power - macmarkus_375.jpg
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, fixed up.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Apr 01, 2011
  • Mark MacDonald
    Mark MacDonald Apr 02, 2011
    Sorry you weren't able to give me a chance to provide further assistance to your dryer problem before rating my first post. Good luck.
    Regards,
    Macmarkus :)
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
I have a samsung DV2C6BEW/XAA that turns on and when you press start just sits there and hums ive already checked to see if the belt was attached and it looks good... Any other suggestions?
Try turning the motor or with the picture you have can you start the dryer and observe the motor? It may be the motor humming and not turning. this could be a bad motor, something stuck in the blower wheel or the tub binding somewhere.
May 27, 2015 | Samsung Dryers
My Samsung dryer DV2C6BEW/XAA will only run for 10 minutes then shuts off and wont come back on for 20 minutes and I have no codes
Your dyer has several "overheat" switches or thermostats built in to prevent overheating and possible fire. You will be needing to "tear the whole thing apart" to find the problem. Start with the air ducting. Easy way to check it is to disconnect the hose from the back and see if it still shuts off too soon. If it does not, your vent to the outside is plugged and is causing the problem. If it still happens, you will need to clean the whole machine of accumulated lint by taking it all apart. Big job.
Then try it. If it still misbehaves, you have a bad "fuse" or "switch" inside the back or the bottom. There are as many as 6 on some models. An electrical tester will help you find the "tripped switch".
Be blessed.
Sep 01, 2013 | Samsung Dryers
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
I have Samsung-7.3 Cu. Ft. 7-Cycle Electric Dryer-White-DV210AEW/XAA SKU: 9739916 this is my first time using this dryer just got it opened the door to check the dryer and closed the door pushed the power...
i would take the plug panel off the back and make sure you are getting the full 220 volts on the terminal,, (it could be in the cord itsself), if that is not your issue, it might be your main board, since it is new i wouldn't tear into it because it will void the warranty
Jan 28, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
I have a new Samsung electric dryer (DV218AEB/XAA)
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067142-/Samsung-Dryer-not-heating-DV218AEB
Click the link for no drum turning. There is a belt in the machine that wraps all the way around it, the belt has come off or broken.
Oct 08, 2017 | Samsung DV218AEW Electric Dryer
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
Samsung DV448AEE Electric Dryer Logo
373 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
