Question about Kitchen Ranges
I have a problem with the ice maker, went i turn it on in ice switch the compressor no running only the the water pump and led indecator is always clean.
  • Kitchen Ranges Master
  • 2,286 Answers
You need to send the model number and brand name of the refrigerator.if it's a G.E. and the reason i ask is that i saw this happen on a G.E. refrigerator,when you hit the ice switch or for water the compressor stops running.the problem is the computer board,the common board number is wr55x10942.
Posted on Apr 01, 2011
My NewAir Portable Ice Maker no longer makes ice. It pumps water up into the resvior but the fan motor never turns on and it does not freeze the water. Why is it acting this way?
is the compressor hot? if so, the fan might be dead. the condenser needs air flow to cool down. if the compressor doesn't even turn on, the starter coil (inside the box on the front of the compressor) may be shot.
Feb 20, 2014 | New Air NewAir AI-100S Portable Ice Maker
Unit turns on and starts to cool. Then runs for about 5 minutes and turns off. Unplug unit and plug back in and it repeats the problem. Will stay running.
It can be issue with temp sensor getting overheated or compressor getting overheated or issue with compressor relay or capacitor.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Marvel 61HK Commercial Beverage Dispenser
My Hoover Frost Free A class HTK 95AA has a trickling water noise coming from the back around the cooling pipes when switched on. The compressor gets very hot although the cooling pipes do not, is it
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Have a hoshizaki kml250mwh... pumps water in...circulates water...compressor freezes the coil...but still no ice. found bad float switch and replaced...made no difference.
If you get ice in the auger the part that makes the ice. Is a bad barring. If fan turn of and there no ice in the auger then is a bad relly on the board .you should have a reset bottom on the board. .
Jul 27, 2011 | Hoshizaki Cubelet Ice MakerDispenser Water...
Machine runs and mixes. Compressor seems to run but mix will not thicken. Seems like mix is not getting cold enough. A water cooled unit.. Tried to bypass water intake switch so water was always...
if its a water cooled unit when the compressor is running water should be running thru the valve, if it isn't be sure you have the water correctly hooked up and its cold water, if it is and still no water you have a bad valve
Apr 03, 2011 | Taylor 632-27 Ice Cream Maker
My ice maker wont work after i changed the filter how can i fix this
After having changed the filter check if water is flowing into the ice maker. If not, check the solenoid valve(water inlet), which it is responsible for!
Next check if the compressor is coming on after setting the thermostat is set and the door closed. If compressor is running, then check if the radiator(coils/vanes) are getting hot or not. If not, there exists the possibility of leakage of refrigerant gas!. Get it filled and adequately sealed.
If the compressor does not switch on at all(For the icemaker) then the thermostat has malfunctioned. Also check the fuses for the compressor!
Hope these preliminary check helps identify the fault. If any warning light/LED lights up, do post it as a comment...........sodeep
Sep 25, 2009 | Whirlpool Refrigerators
The Kenmore Ice maker makes no ice. This is a side by side unit. The freezer is very cold. The water solenoid is not faulty, but is not turning on so the problem must be in the electronic ice level...
Good chance the water line near the ice maker motor is frozen. Thaw out the freezer for about 6 hours - move your frozen stuff to the refrig - ot should be OK - then back again after thawing. This alnost always works.
Aug 10, 2009 | Refrigerators
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
Jul 15, 2009 | Kitchen Appliances - Others
U-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
May 24, 2008 | U-Line Icemaker
Kitchen Ranges Logo
63 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
