Question about Dometic NDR 1292 Refrigerator
How do you remove doors on model NDR1292 side by side refrig and freezer
    Top Expert:
  • Dometic Master
  • 14,161 Answers
Posted on Jun 14, 2015
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Dometic RV refrig model NDR1292 seal on right door
Here's a link to number to call for info on replacement parts available.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Spare-Parts/
Posted on May 27, 2010
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
May 20, 2010 | Dometic NDR 1292 Refrigerator
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
Have a dometic ndr1292 side,freezer works fridge at 60 degrees
Try to defrost it. unplug fridge and place a box fan in front blowing at it. keep the frigd controls in the midle range as well as the freezer control
Sep 05, 2009 | Refrigerators
Dometic model ndr1292.my water tube for ice maker is falling apart.how do i replace it?
it depends on whether you can get to the back of refrig from the out side. if you are lucky enough to have 2 access panels behind the refrig you are able to do it without removing refrig. i just replaced mine. i bought an ice maker kit at home depot and just used the hose and fittings cutting the hose to size. if you are in cold weather i would recommend using the heater wires that are wrapped arount the old tube. they keep the water from freezing. hope this helps.
Jul 15, 2009 | Dometic NDR 1292 Refrigerator
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
May 30, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Dometic NDR 1292 Refrigerator Logo
108 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
