Question about John Deere Garden
I want to disconnect the reverse engine cut-out on a scotts s2554 with an auto trans.I need to push the clutch switch in order to use reverse when the deck is engauged. I understand this is a safety,but is also causing a lot of use on my clutch.
5 Suggested Answers
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
SOURCE: I have a John Deere X300 garden tractor. When
I have a John Deere X300 lawn tractor with an intermittent starting problem. From time to time, when you turn the key all you get is a click. Battery is connected, headlights work, but starter will not turn. Keep turning key off and on and eventually it starts. Other times, it starts just fine. What parts should I start replacing?
Posted on May 24, 2011
Need service manual for scotts riding lawn mower. model # s2554
try www,manualslib.com/manual/149701/Scotts-S2048-S2554.html
Aug 14, 2016 | John Deere L100 Series
I have a Scotts s2554 runs great but when i ingage the blades it shuts the engine off
Grass box is either not fitted correctly or the safety switch on the grass box is not fully depressed or working. This applies the safety brake to the blades, puts weight on the engine which overcomes the engine power and stops it from running. Disengage the blades and the engine picks up again. To test, take the wires off the safety switch and connect together to simulate an activated switch. If it then runs ok, you found the problem.
Sep 04, 2015 | Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Where is reverse switch located on 2001 saturn sl?
for a std trans its on the top of the trans below but to the back side of the battery on a auto trans its on the back side of the trans below the brake master cylinder
Aug 14, 2012 | 2001 Saturn SL
Scotts Lawn Mower S2554 Goes Dead When I Let Off Clutch
check the safety switches i would start with the one under the seat with your problem
Mar 27, 2012 | Garden
When i turn the key the engine wont turn over but i have power to everything but the motor
is the car a manual transmission or an automatic? if manual there is a switch on the clutch pedal that wont let engine turn over unless clutch is pushed to floor.automatic it is mounted on transmission at the linkage.for auto trans you can move shifter back an forth while trying to crank engine. if manual you can push clutch pedal to floor hard an try to crank.
Mar 21, 2011 | 1988 Ford Mustang
HELPING A FRIEND WITH A CRFTSMN 18HP FRNT ENGINE LT2000 LAWN TRACTOR. THE ENGINE RUNS GREAT BUT WHEN HE RELEASES THE CLUTCH/BRAKE TO GO FORWARD OR REVERSE THE ENGINE DIES.
Put trans in neutral if trans is a gear drive and see if mower can be pushed, if it can you can push rule out stuck brake. If you have a hydrostatic trans you can put trans in bypass and push to see if brake is stuck. Remove drive belt at engine or at trans and try the cluch, if motor stays running there is a trans problem.
Mar 13, 2010 | Craftsman Garden
How to repair clutch pedal safety start switch on Ford Truck F550, 1999
Clutch Pedal Position (CPP) Switch
The clutch pedal position switch (CPP) is controlled by the clutch pedal. Depressing the clutch pedal manually closes the CPP switch and allows engine cranking. The CPP switch will also deactivate the speed control system.
303-14A: Electronic Engine Controls — Gasoline Engines 1999 F-Super Duty 250-550 Workshop Manual
REMOVAL AND INSTALLATION Clutch Pedal Position (CPP) Switch Removal
  1. sxo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always disconnect the battery ground cable prior to working on the electronic engine controls.
    Disconnect the battery ground cable; refer to Section 414-01 .
  1. Disconnect electrical connector from clutch pedal position switch (CPP) (9A837).
  1. Release the clutch pedal position switch (CPP) (11A152) from the orientation clip.
  1. Remove the plastic retainer.
    1. Push the lock tabs together.
    1. Slide the plastic retainer off the clutch pedal position switch.
  1. Remove the clutch pedal position switch.
Installation
  1. Follow the removal procedure in reverse order.
Feb 06, 2010 | 1999 Ford Super Duty F 550
2002 Ford Ranger Clutch Problems
It's not the clutch, it is the clutch slave cylinder. Check the fluid level in the clutch master cylinder and you will see that it will be empty. The problem is the trans has to be removed to replace it.
Jan 13, 2009 | 2002 Ford Ranger Regular Cab
Garden Logo
109 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
