Question about Philips J44414
Can u fix my devioce - Philips J44414
PCI bus 4, device 4, function 0 dell driver
assuming XP, right click My Computer, Manage, Devioce Manager and look for the yellow question mark ... this should give you some clue as to whats wrong ..
Apr 14, 2014 | Dell Computers & Internet
What is city area code of doha qatar
hello;
select your place codes with sub codes: 974284250 9741121127 XES Emergency Services 974124522094 XVM Voice Mail & SMS 97421738223 PAG Paging 9742244520 PAG Paging 974286 Fix Line MATS 9744137128 Fix Line MATS 9744289375 Fix Line MATS 9744341613 Fix Line MATS 97443041613 Fix Line Doha Central (DC3) 97443141613 Fix Line Doha Central (DC1) 97443241613 Fix Line Doha Central (DC2) 97443341613 Fix Line Doha Central (DC1) 97443441613 Fix Line Doha Central (DC2) 97443541613 Fix Line Doha Central (DC3) 97443641613 Fix Line Doha Central (DC2) 97443741613 Fix Line Doha Central (DC3) 97443841613 Fix Line Doha Central (DC3) 97444563138 Fix Line MATS 974440563138 Fix Line Doha Central (DC3) 974441563138 Fix Line Doha Central (DC1) 974442563138 Fix Line Doha Central (DC2) 974443563138 Fix Line Doha Central (DC1) 9744431599563138 Fix Line PSTN Testnummer 9744432599563138 Fix Line PSTN Testnummer 974444563138 Fix Line Doha Central (DC2) 974445563138 Fix Line Doha Central (DC1) 974446563138 Fix Line Industrial (IEC) 974447563138 Fix Line Doha Central (DC2) 974449563138 Fix Line Doha Central (DC1) 9744546098 Fix Line MATS 97446196683 Fix Line MATS 974460196683 Fix Line Industrial (IEC) 974461196683 Fix Line Industrial (IEC) 974462196683 Fix Line Airport (APC) 974463196683 Fix Line Rayyan (RYC) 974464196683 Fix Line Wakrah (WKSC) 974465196683 Fix Line Airport (APC) 974466196683 Fix Line Airport (APC) 974467196683 Fix Line Airport (APC) 974468196683 Fix Line Industrial (IEC) 974469196683 Fix Line Industrial (IEC) 97447252915 Fix Line MATS 974471252915 Fix Line Rayyan (RYC) 974472252915 Fix Line Khuratiyat (KRC) 974473252915 Fix Line Doha Central (DC3) 974474252915 Fix Line Doha Central (DC1) 974475252915 Fix Line West Bay (WBC) 974477252915 Fix Line Wakrah (WKSC) 974478252915 Fix Line Khuratiyat (KRC) 974479252915 Fix Line Khuratiyat (KRC) 974482826 Fix Line MATS 9744802826 Fix Line Rayyan (RYC) 9744812826 Fix Line Rayyan (RYC) 9744822826 Fix Line Rayyan (RYC) 9744832826 Fix Line West Bay (WBC) 9744852826 Fix Line Doha Central (DC1) 9744862826 Fix Line Khalifa Town (KTC) 9744872826 Fix Line Khalifa Town (KTC) 9744882826 Fix Line Khalifa Town (KTC) 9744892826 Fix Line Khalifa Town (KTC) 9744955072 Fix Line MATS 974507311 Mobile Mobile GSM 9745211796 Mobile Mobile GSM 97453192116 Mobile Mobile GSM 9745416281 Mobile Mobile GSM 97455548189 Mobile Mobile GSM 9745620766 Mobile Mobile GSM 9745825251 Mobile Mobile GSM 974593 Fix Line Fixed Telephone Cellular 97459383 Mobile Mobile GSM 97459393 Mobile Mobile GSM 97490097012 XAT Audio text Services
Feb 21, 2011 | Computers & Internet
I had speaker but unable to listen songs . i usally get the message of no sound devioce installed on your pc
must be problem with your sound driver ...try to reinstall the driver and check it.
Jul 12, 2010 | Computers & Internet
Have setup in this order dsl modem,dir615 router,spa2102 phone adapter,get dial tone,hear ringing when making or receiving calls but no voice,what gives??
incoming voice ports are not open on the router. the devioce uses one IP port to set up the call (ringing) and at least 2 others for audio. read the manual I'm afraid.
Nov 06, 2009 | Computers & Internet
Black berry bold unable to connect to data services while roaming
It might be worth looking at whatever plans you have. When you unlock your blackberry it still needs a sim card from some provider. When you unlocked and put in your new simcard, you bought some sort pf alternate phone/ Data plan did yopu ask for a mpa of areas that your nwe plan works from? They usually have a map of coverage that will show you if you had coverage in mexico. If not then it has nothing to do with the unlock it has to do with whatever provider you use doesnt servoce the area. Then tyhe answer is to get yuet another sim vcard with another plabn that works there. . Addtionally depending on where your blackberry came fromm it simplymay not puick up the proper frequencies as phones in meixco use,.. I know people who got their unlocked decvice from the middle east or africa or south america and those devices simply don't use the same frquency as the US or Canada does. If your device was orignally from Rogers then if you have no probnlem with getting services to work in the US or canada or even the US virgin islands which Roghrs does cover but at an astoundingly high Calling and Data rate ( like $1.35 Per minute vouice and .35 cents per KB in the carribean .. then it might just be the phones settingts which RIM puits in depending on whare they intend to have the device sold ..they seell worldwqide so if your fivice was designed fo Asia it simnply might not use the bsame frequency as US or candain devices
Check the coverage map of whatever planyou have from whatevber alternate provider your going wiyh ..you had to get another sim cartd to get the devie working. That sim card has to be attched to some sort of data and voice plan. check the coverage and then look into where you bought your blackberry and whre yuour tring to use it from . if it's rogers check and see if the devioce itself wll work in Mexico ..it just might not. Riogeers isn't really interested in making it easy for you to use servoces from far awat. Theres no compitition and as small population. They don;t have to do anything more then possible, I have had a regular cell from Riogersa that worked throughout the carribean..but nbot in othr arteas at all. . I have a blackberry noi but I have another friend who went deeply into brazil and other areas and while devices locally bought( even smart phiones) worked. Devices bought in North America don't work in some countries. It;s like DVD encoding. If you buy a DVD that is coded for the Middle east it won"t play on your DVD thats supposed to be for use in North ameica. Smart phones have some simiolar restrictions locked or unlocked ,
Mar 28, 2009 | RIM BlackBerry Bold 9000 Smartphone
I have dell speakers hooked up to my dell pc but NO sound.
  • Ensure the connection first if the connectors are hooked up to the correct port.
  • check if the speaker is receiving the power there should be an indicator lit up
  • If you have an integrated sound card make sure they are not disabled in BIOS.
  • Then check if the sound drivers are properly installed.
  • check the volume control to ensure if mute is checked(uncheck it) also ensure the volume level it needs to be set to a level so that it's audible to you.
  • Do check the speakers with another devioce to ensure the speakers are fine and working.
  • FOR MORE SPECIFIC INFO PLEASE PROVIDE THE MODEL AND BRAND DETAILS OF THE PC AND SPEAKER AND OS
Feb 21, 2009 | Dell Audio Players & Recorders
How can i resolve the error code 88780078 shown by winamp
Try going into the device manager and removing the sound driver. Hopefully you have the sound card driver. Then reboot the Pc if the system installs the driver software and you hear noise your good. If that doesn't install it from your cd. If it works try uninstalling the program that caused the problem.
Nov 29, 2008 | Audio Players & Recorders
Can the Zune sync with Windows Media Player?
There is a way and none of your solutions work. There is a software you can download and use as a Hack but the problem is that is does not work with Windows XP/Vista/7...Windows Media Player does not recognize the Zune as a devioce or a player, just like Windows will not recognize it as a storage drive in Windows Explorer. You would figure with Zune being a Microsoft Product, that it would work well with other MS products but they screwed up somewhere and did not get the memo that Zune is a MS product
Apr 24, 2008 | Microsoft Zune 2nd Generation Digital...
HP PAVILION a305w
try getting into the bios and setting it to boot normally, turn off fast booting if its an option thats on, also, set your CD drive as the first boot devioce, then hard drive. Save and reboot, have CD in drive and just start hitting the F10 key as soon as it starts up, usually you hear a Beep when it detects that you are hitting the key for the boot options. HP pavilions where made to start and skip through the Post Process quickly to limit waitnig time, of course this sux when you want to boot from a cd.
You could try remove ing the BIOS Battery off the board and unplugging the system, wait a minute for it to discharge and put it back in, power it up and see if it lets you boot from CD.
Your bassically resetting the BIOS to factory defaults.
Also, i dont recomend buying HP Pavilions. i wokred on three seperate ones that a customer thought was a New machine ( this was back in 2001 ) but all the parts where 1995 parts, which means wghen they tried to upgrade to windows XP, XP doesnt have any generic drivers for hardware that old so nothing worked and yuo cant find any driver online that are that old.
Good luck anyway.
Feb 15, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Philips J44414 Logo
147 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
