Question about Porter Cable 5,500 Watt Portable Generator #BSV550 W...
What type and weight of oil do you use - Porter Cable 5,500 Watt Portable Generator #BSV550 W...
  • 710 Answers
Porter Cable recommends straight 30 weight synthetic oil for their engines. However, If you live in a colde climate or in a hot climate, the use of multi-viscosity oils is my recommendation. Straight 30 weight oil in my cold climate would not work. So, it really depends on where you live.
30/5 works well in a cold climate like mine.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Posted on Apr 01, 2011
What kind of oil replaced the Harley Davidson type "c" oil fork ina SS Sprint 350cc?
Fork oil is the same as hydraulic pump oil. Depending on your preference choose a light weight oil, 5-15 will give a soft ride. As the weight numbers go up the comfort level goes down. However, the heavier weight oil provides better handling. A bit of experimentation will varying weights should be considered for the optimal combination of ride comfort and handling. One final note. Always. Purchase a non-detergent oil
Nov 21, 2015 | Harley Davidson Fork Oil
What type of oil for yard machine 16.5
30 weight oil only it will say thirty weight on bottle do not use 10 w 30
Sep 02, 2014 | Yard Machines 13AN775S000 500cc 16.5 HP...
Dont know what type of oil to use
Put straight 30 weight motor oil in it. Not 10W30 or any multi-viscosity oil. Straight 30 weight motor oil. If you're doing a complete oil change, then you may want to use Synthetic 30 weight, which will last longer between oil changes and also make your engine last longer (but it costs more too). Best of luck to you.
James
Sep 12, 2011 | Toro Power Lawn Mower
I have a1974 FLH front end with 2 in. over stock tubes. What weith oil and how much sho uld I use in each fork. This front end is on a all steel (1000lb) VW Trike.
The service manual says to add 7 ounces of Type "B" oil to the "dry" stock tubes. I'd probably try 7 ounces of PJ1 30 weight oil in that machine to start with. Then, you may have to adjust the quantity and oil weight to get the ride you want. From my past experiences with these types of machines, the biggest problem you're going to have is lightness in the front end. They will "wheelie" very easily and may even "hop", front wheel bouncing, when going down the road in extreme cases. It may turn out that you need more damping action in which I'd try the "wet" quantity of 6 1/2 ounces of 20 weight oil. The "wet" or "dry" quantity means that if you took the fork tubes apart and all the oil is out of them, they're considered "dry". A simple drain and refill is considered a "wet" oil change. I think Honda actually offers a 25 weight oil. I've seen fork oil weights available down to 5 weight. You'll just have try it and see what it does.
Good Luck
Steve
Aug 23, 2011 | Harley Davidson FLHT Electra Glide...
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Steve
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
For the Skil 77 worm drive circular saws what type of oil is required?
Use 90 weight gear/differential oil but if you use it outside in the cold weather it's too thick, use 40 weight oil then and switch to the 90 weight in the summer.
Jun 03, 2010 | Saws
What type oil. the weight
For 1994 Ford Taurus 3.0L EFI 6cyl the Engine Oil Type and Weight is:
4.5
Application:
Oil for use in all temperature ranges
Quarts with filter change
VV174
Application:
Valvoline Premium Conventional 5W-20 Motor Oil
Hope thos help (remember rated and comment this) Good luck.
Mar 29, 2010 | 1994 Ford Taurus
Porter Cable 5,500 Watt Portable Generator #BSV550 W... Logo
256 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
