Question about Casio F91W-1 Wrist Watch
How do I change the date on my casio F-91W - Casio F91W-1 Wrist Watch
5 Suggested Answers
kerguney
  • 577 Answers
SOURCE: lost manual, need to set
Hi,here is the user manual..
soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Posted on Jul 02, 2011
  • 135 Answers
SOURCE: For Casio F-91W how do I replace battery? I see 4
yes you need to remove the 4 screws, an eyeglass repair kit works great, but take them out and you should see the battery. there will probably be 1 more screw to remove battery
Posted on May 11, 2009
SOURCE: how can you make a "Casio f-91w" watch not beep
take the back off and take out the watch from the housing/strap (it should lift out complete with the battery). Put it all back and screw the back on. Don't know why, but the sound will no longer work! I've done the same to mine.
Posted on May 10, 2010
SOURCE: How do you turn the
ho do i set my f-91w
Posted on Aug 16, 2011
How can I make my Casio F-91W watch beep every hour?
Deron, Check the attached links,manual,instruction and guides, Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Casio 91W User Guide Quick guide to set the time and use all the functions
How do you turn off hourly beep on casio 91w
Casio F91W Module No 593 Watch
Apr 24, 2016 | Casio Watches
Ae 91w
THE CAPACITOR OF MIGHT HAVE SHORTED.
PLEASE GO TO AUTHORISED SERVICE. NO PERSONAL REPAIR IS DONE.
Apr 19, 2014 | Casio Watches
Problem with day/date changes! My casio edifice
follow these instructions off the manual below if you set the watch in wrong sequens it wont change at 12 oclock
http://support.casio.com/en/manual/009/qw5125.pdfhttp://support.casio.com/en/manual/009/qw5125.pdf
Sep 27, 2013 | Watches
Casio not working
You need to Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs to get the watch started
Jul 29, 2013 | Casio F-91WG-9QDF F91WG 9 Digital Alarm...
Hey, I recently bought a Casio F-91W but it was supplied without a user manual so basically I'm having problems setting the date, time, etc. I have been onto the Casio website to try and download a...
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Thanks
Jun 23, 2011 | Casio F91W-1 Wrist Watch
I have a casio f-91w, and i would like to know how to turn on the hourly chime.. please help.. thank you.. peter.
I've never used one of these watches, but after looking online, I think this is how it's done:
Try using the top-left button to cycle through the settings, and use the button on the right to change them. So I'd imagine that after pressing the top-left button enough times, the indicator for the hourly beep will start to blink. At that point, press the rightmost button.
The indicator on the face of the watch should light up to indicate that the hourly chime is enabled.
May 10, 2011 | Casio F91W-1 Wrist Watch
Lost manual, need to set time... I have a Casio, model F-91W
Thanks
Apr 27, 2011 | Casio F91W-1 Wrist Watch
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
May 11, 2009 | Casio F91W-1 Wrist Watch
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Casio F91W-1 Wrist Watch Logo
2,039 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
