Question about GE WJSE4150B Top Load Washer
Our top load GE washer leaves a lot of suds when washing towels, even though I use a minimum of detergent. Also I notice that sometimes there is a tiny amount of water at the bottom when the load is finished. Is it not draining properly?
  • 415 Answers
If you recently washed a rug perhaps and it came apart a babys sock or something came apart then it sounds like the pump is part restricted and will have to be cleaned.
Posted on Apr 01, 2011
Suds message
The suds message usually means that there was too much detergent in the machine for the load. Remember to use a HE detergent and use the recommended amount. For a small load, use just enough detergent to reach the minimum detergent line (if there is one). Otherwise, you should use about half of the usual amount of detergent for a small load compared to a large load.
Usually the washer will add an additional rinse to remove the extra suds. If you notice detergent is still on your clothes, run the load through the washer on the same cycle without adding more detergent.
The manual for several versions of the Whirlpool Duet GHW9150P are available from GE: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFlibuKNJvC4qU4ramPrjJ75r2vuMTp0sZ%2F7cWgUj2a5ZKg%3D%3D&ddkey=http:OCManualsLiteratureSearchResultView . Alternatively, start here: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html and enter the model number and click the right arrow.
I hope this helps.
Jul 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Odor from your towels or clothes washer?
With newer higher efficiency washing machines flooding the market today, new issues arise. One annoyance is odor of mildew on towels or coming from the front load or even top load machines.
With a little maintenance and care this trouble can be eliminated and avoided in the future.
If you currently have the odor locate one of the following products
- Affresh
- Smelly Washer
Run the hottest cycle without clothes and the product you chose. If the washer is especially bad you may need to run a second clean out using another dose.
After the washer is clean be sure you only use the recommended detergent for your product. HE detergents are required for most all front loading machines and a lot of new top loading machines too. This is very important, because if the wrong type is used it can cause build up in hidden areas that will cause odors as well as performance issues and even premature failures of components.
Do not use any additives that are not recommended for your machine, check with the manufacturer or owners guides for specifics.
Leave the lid or door open at least partially when not in use, this will move air through the unit to help keep odors away.
Use the Affresh or similar product once a month in the machine to keep anything from building up where you can't see.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
Wont Stop Filling http://www.fixya.com/TipsAndTricks/preview.aspx?thid=4621172
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
Display window saying "Suds" and nothing appears to be happening inside; just seeing lots of bubbles. Did a cold load of bathmats, set on "towels" for extra rinse.
You have apparently used an excess of detergent for this process. Try draining the suds out to a reasonable level, then resume the wash if you can. Hope this helps!
Aug 05, 2010 | Samsung WF328AA Front Load Washer
Towell cycle taking longer than before
The washer only uses a tiny amount of water to do them clothes. If you use more than a teaspoon of HE low sudsing detergent that washer will detect suds and take extra steps to rid the suds. This causes motor problems.
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Too many suds even after running the rinse cycle while empty of any clothes
Some of these new top loaders require Frontloader detergent.I know F&P Aquasmart does.if you are useing Topload detergent it maybe over sudsing.Even though its a top loader some of them are ment to use Front load detergent..Fill with water & flush several times.check your book for type of detergent to use or ring & ask F&P.
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
Nov 24, 2009 | Electrolux EW1000i Front Load Washer
Suds in the floor...
are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Dec 29, 2008 | GE WBVH6240F Front Load Washer
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
Dec 29, 2007 | LG WM1814CW Front Load Washer
GE WJSE4150B Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
