Question about Acer AL1711 17" Flat Panel LCD Monitor
Acer al1711 flashing green light no menu no picture,after a few minutes the green light stays on but still no picture menu or anything ...help please
  • 4 Answers
Hi.  I have no experience with an AL1711 but this sounds very much like the power supply problem that affects the AL1715.
If you understand electronics then you need to check the power supply for faulty components (there were two faulty capacitors in my AL1715).  Replacements should cost about 10p each and however much time it takes.
Unfortunately if you're not into electronics then there's really not much you can do.
If you do take the back off then please post whether you can see any faulty components.
Zeb.
Posted on Aug 05, 2008
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Acer al1711: two monitors with same problem
The most likely cause is blown capacitors on the power supply/inverter board. Go to our web site at: www.ccl-la.com/badcaps.htm we have pictures of what the capacitors look like when the blow out. We also have some dis-assembly guides that may help you. Just open the back of he monitor and look at the board, replace all the blown capacitors that look like the ones in the pictures and you should be back going. The values hat you will need are going to be marked on the sides of the bad caps. Be sure to use a low ESR and high temp replacement or you will have to do this again in a month or two. We carry the proper caps in stock if you want us to supply you with them. The caps at Radio Shack will not do. When you replace the bad ones be sure to install the new ones with the polarity stripe on the side going the same direction as the old ones come out. If you have any additional questions just let me know.
I hope this helps, if you please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 18, 2009 | Acer AL1711 17" LCD Monitor
After a short power outage (2 minutes max) my monitor ( acer al1711)cannot display green. Is the problem the monitor or the drivers?
It sounds like a surge may have damaged the monitor. Try rebooting your system, and if that doesn't work, reinstall the drivers. If the problem persists, the monitor may have been damaged by a power surge and it may have to be serviced/replaced.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Acer AL1711 17" LCD Monitor
Volume box keeps popping up on my Acer AL1711
This is a problem of menu switches.You need to replace switches.
Samir.
Please rate the solution and write back if you need more help.
Jan 03, 2009 | Acer AL1711BM (Black) 17" LCD Monitor
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Acer LCD AL1711 Monitor Flashes Colors
Main power supply, and or the backplane power supply, and or the backplane lamps usually cause this.
The fix is to try new modules using the process of illimination. Once the defective modules are determined, the new ones must stay in the monitor.
That is the process used to service this monitor.
Jerry G.
Jul 15, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
What is wrong with my AL1711
This is possibly an inverter. When the monitor goes out, examine the LCD to see if you can see a faint image of the video being displayed. IF so, replace inverter. If not, possibly a bad LCD or video circuitry.
Dec 07, 2007 | Acer AL1711 17" LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
Acer AL1711 17" Flat Panel LCD Monitor Logo
290 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
