The printed copy shows the red color as pinkish or magenta.
    Genius:
  • 1,288 Answers
Assuming that you have the printer set up correctly and are using the latest drivers for the printer and the printer software, this is probably caused by clogged ink nozzles in the black, yellow and cyan inks. It may also be down to compatible rather then geinuine inks being used. Try the print head clean function and see if that helps
Posted on Apr 01, 2011
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
Bizhub C654e Color Copy Only show Cyan or Magenta Lines
So you have tried all the calibration tests? It sounds as if the alignment is off. If that isn't the case, you can try setting the copier back to default settings. I think in this make the reset button will be a tiny indented hole on the back.
Elisa Jed ' http://stores.abmcopier.com/canon-color-pre-owned/
Apr 13, 2014 | Office Equipment & Supplies
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Making Only megenta color copies no other color
When the blue color ink is finished it may print magenta instead of blue. And it is clear that black,yellow,red colors are there.
Jun 18, 2010 | Ricoh Aficio CL3500N Laser Printer
Yellow is missing in printouts, and the color is heavily purple, even after putting in new red cartridge and doing a deep clean
Yellow cartridge is clogged or bad. If yellow is not being out put then it will throw the other colors off. You could print a yellow, light blue, magenta (pinkish) , and black squares using MS paint or other paint program. This will narrow down which cartridge has a problem.
May 14, 2010 | Canon PIXMA MX850 Multifunction Printer
Colour problem
If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
Dec 24, 2009 | HP LaserJet 3000n Printer
Epson R800 Red Color Problem
Actually magenta is the weakest compared to cyan and
yellow using even K3 inks. Now epson is releasing
K3 with vivid magenta ink. Using any color management
I have found it very difficult to reach a real red without
a lot of tweaking in my color profiles. Now it appears
that Epson sees the problem and is changing magenta
out for vivid magenta ink to solve the weak magenta.
Jul 17, 2008 | Epson Stylus Photo R220 InkJet Printer
Printing color copies
check to see which cartridge you put in, photo magenta cartridges DO NOT work in the MP830. sounds silly but we see it all the time.
check to see if the short vertical black bar next to the magenta pattern looks ok, not brown or gray or streaky. if it is you may need a professional head flush, take the whole printer in for service.
Jun 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Computers & Internet Logo
David Payne
David Payne
