Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Hey. Im having a problem with my samson g track when mixing down midi and audio. The midi comes out really quiet even though its on full volume. It doesn't mixdown correctly. I'm also finding it impossible to convert midi into audio and keep the same sound as I have before I try to mix it. Hope you can help. thank you.
  • 51 Answers
MIDI isn't audio, think of it as a sheet of music. It still needs to be played to be heard. Not sure of your recording setup but the midi performance that you have needs to trigger a keyboard or drum machine or VST instrument of some sort.
Posted on Apr 03, 2011
Hi, in properties in the volume control tab, recording.. the usb audio codec has no volume controls and it will not allow me to highlight the usb device for recording. im using xp 64
Hey same problem here, mine is also not enabled the volumen controls on control panel or sound controls for windows xp sp2
have you find the solution for this, i contacted to samson, but they didnt send me any solution (just to send it for repair)
Oct 29, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
Cant get my computer to recognize my samson G track mic
Check audio drivers ..I re-installed my Audio drivers and it worked fine for me ...
Nov 12, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Ps2
The ps2 has a sound threshold, which it cannot surpass. Do you hear any volume at all? If you hear NO volume, verify that your audio visual cable is properly seated in both the TV and the console. If you hear some volume, and its just really quiet, try a different TV.
Apr 30, 2008 | Sony PlayStation 2 (PS2) Console
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
74 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
