Question about Amana Refrigerators
The refridgerator compartment does not seem to be getting cold, the freezer compartment is fine.
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
5 Suggested Answers
lojacksdad
  • 121 Answers
SOURCE: I punctured the freon line in the freezer, will the refridgerator still work.
no sorry to tell you this type of problem is not worth repairing
Posted on Apr 17, 2009
  • 2692 Answers
SOURCE: top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
Posted on May 08, 2009
  • 12 Answers
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
Posted on Sep 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: refridgerator not cold
Hi and welcome to Fixya. When a food section of a refridgerator warms up it is a sign that the unit is not defrosting or there is an air flow problem.
This can be caused by the following components:
1. The defrost timer
2. Defrost bi-metal 60 Deg thermostat
3. Heating element
4. Evaporator fan failure in the freezer compartment
Sometimes the defrost timer will just stop advancing for some reason and ice builds up in the evaporator coils that restircts airflow from the evaporator fan so the food section warms up.
The most likely failure is the defrost timer.
You can see if your uint will cool properly after a good defrosting by doing this:
1. Unplug the unit and unload the freezer section
2. Place a fan blowing into the freezer for about 2 hours. (it will make a water mess so be prepaired)
3. Plug in / restart the unit and monitor the temperature for the next 48 hours (it should be normal or near normal) After 48 hours the food section temp will start to raise again due to ice build up.
4. If the temps return to normal then the unit is not defrosting properly and will need repaired.
You can find replacement parts here:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=KSRB22FHBL01&mfgModelNum=&fkMfgID=3
From the model number you gave the defrost timer is Item 6 of the control diagram
http://www.partselect.com/PartDetail.aspx?Inventory=372261&SourceCode=1#
It can also be found here:
http://www.repairclinic.com/Appliance-Parts?s=t-KSRB22FHBL01-%3d%3d&z=50
http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRB22FHBL01-%3d%3di844415&PartID=844415
I did not of course diagnose the unit in your home. The part above is the most common failure. Given the cost of the defrost timer I would make SURE that it was defective before ordering.
In order to perform a continuity check of the rest of the defrost system components the bi-metal 60 Deg F thermostat must be above 60 Deg (or jumpered) to read the whole circuit. Jumpering the 60 Deg thermostat will not verify it is working correctly.
Hopefully this gives you a bit more understanding of why your unit is warming up in the food section.
Posted on Feb 04, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
The Refridgerator compartment won't keep cool , but the freezer works fine. Would it be the thermerstat or compartment dial
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Refrigerators
The refridgerator compartment is not working while the freezer compartment is working fine
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 24, 2010 | Whirlpool Refrigerators
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Aug 28, 2010 | Kenmore Refrigerators
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
May 08, 2009 | Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Refrigerators Logo
223 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
