Question about Dryers
My Fisher Paykel front load electric dryer DEIX2 shuts of erratically (sometimes before the clothes are dry and sometimes long after they are dry). It sounds like the moisture sensor is not working. Lately the hi limit thermostat breaker kicks out periodically too. Resetting works to allow heating elements to work. I have checked the vent, lint filter, cleaned the sensor element bars with alcohol, cleaned lint out of inside of cabinet, and visually checked the heating elements. Everything seems fine. I suspect one or all of the 3 thermostats, or the sensor module 395628P. However, I am unable to identify anything that looks like the sensor module inside the cabinet. Help!!!
  • 13 more comments
  • staudtlar Apr 01, 2011
    Daniel,
    I am unable to find a thermostat at the rear panel. If you could refer to the parts manual athttp://www.fisherpaykelparts.net/partman... it would help. I am able to identify only the following thermostats on page 19 of the manual: 5 - manual reset 395155, 7 - auto rest exposed disc 395668, 26 - auto reset 395455, and NI (don't know what that stands for) - under 395616 Harness Elect. Element & Mains IEC - auto reset exposed disc 395668 All of these thermostats are found on page 19 Base Panel & Components.
    If I understand correctly, if the connectivity between the contacts on the thermostat is open (reading infinity) the thermostat is good, and if closed (zero ohms) it is bad. Is that correct? Can you tell me which one of the 4 thermostats you would suspect?
    One reads infinity and the other reads zero, so it looks like we found the culprit. I tested the thermostats while the dryer was still hot after turning off from running a load. Will this make any difference?
    Daniel,
    Now that the machine has cooled down, both thermostats check good (zero ohms)????????
    Daniel,
    I'm not sure you got my last comment??? After the dryer cooled down, I checked the thermostats again and they both checked good. Now what????????
    The dryer was unplugged when I checked the thermostats.
    There are only 3 thermostats and they all check good. The one that originally checked bad, checked good when the dryer cooled down.
    That thermostat no longer checks infinity. It did that only when the dryer was hot. After it cooled down, it checked zero.
  • staudtlar Apr 02, 2011
    Would you please review my problem and give me any solutions you may have. It seems to me that so far we have established that it is not one of the 3 thermostats. Do you concur? Incidentally, I made a mistake in describing the dryer. It is a top load, not a front load. You may want to reference the parts manual athttp://www.fisherpaykelparts.net/partman...
    The thermostat in question reads infinity when it is hot right after the dryer is turned off, and returns to zero very shortly (within seconds) after the dryer is shut off. I have removed the thermostat (no. 7 and part no. 395668 in the parts manual), and it has no temperature inscribed on the case. Is it not safe to say this thermostat is good?
    Jahn, further inspection of the thermostat shows part of the numbers being L70-15C. That could mean 70-15 deg. C, or 158 F - 59 F. 158 deg, F would seem about right.
    Inspection of the second thermostat (#26 in the parts manual & part #395455 also shows L70-15C (158-59 deg. F). It reads zero ohms when dryer is hot and after cool. It is placed farther away from the heating elements though.
    If the thermostats are good, I guess it could only be the "Module Sensor Assy." Would that seem reasonable to you? Wish I could be sure as this is an expensive part ($87.06) and difficult to replace. What do you think?
    Okay Jahn, I'll check connections and then order the module. I'll let you know if the new module fixes the problem (not sure how long it will take to get part and install). You were most helpful and I will accept your solution.
    I won't really know until I get the new module and install it. I'll make a new post when that happens.
    President:
  • 1,554 Answers
A good thermostat reads zero ohms when cool and infinity when hot enough to cycle off. A bad thermostat reads infinity when cool, infinity when not hot enough to cycle off, or zero when hot enough or even hotter than is cycling temperature. The temperature marking on the thermostat is its temperature rating on which it cycles off and should read infinity.
The sensor works only when an auto-dry cycle is selected. The bars or wires are shorted if the dryer doesn't shut off after the clothes are dry and open or the connection is cut open or loose if the dryer shuts off before the clothes are dry.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Apr 02, 2011
  • 2 more comments
  • Jahn27
    Jahn27 Apr 02, 2011
    Well, the function of the thermostats is to momentarily cut off power to the heating element to regulate the drying temperature and prevent overheating. They are not used to send signal to the module sensor assembly to shut off the dryer. Only the sensor bars are designed to send signal to the module sensor assembly by detecting the moisture content of the clothes and this happens only in the auto-dry mode.
  • Jahn27
    Jahn27 Apr 02, 2011
    Thermostat in question is therefore good.
  • Jahn27
    Jahn27 Apr 02, 2011
    It is reasonable that it's the Module Sensor Assembly if the sensor bars are clean and the wire harness connecting it and the former is intact the connectors are snug fit.
  • Jahn27
    Jahn27 Apr 02, 2011
    Just update us about the result.
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 01, 2011
  • 7 more comments
  • Daniel Scott
    Daniel Scott Apr 01, 2011
    Thanks for your reply....you have to check them for continuity no continuity means they are bad and should be replaced
  • Daniel Scott
    Start with the auto reset one and if it reads open then its bad if it reads 0 ohms then its good
  • Daniel Scott
    Nope thats fine you can replace the one that is bad
  • Daniel Scott
    Unplug the dryer and then check and also check the other two
  • Daniel Scott
    If the dryer was unplugged then check all four parts that you told me for continuity and replace the one thats bad
  • Daniel Scott
    The dryer shuts down erratically because of that thermostat that checked infinity
  • Daniel Scott
    I know that I am reading what you are writing but I believe thats bad, if you want to be sure then check/test the door switch before replacing this thermostat
  • Daniel Scott
    Daniel Scott Apr 02, 2011
    if its a top load then check the lid switch assembly before replacing the thermostat....I still believe it is the part that read infinity causing erratic shut down.....
  • Daniel Scott
    Hey....also let me know if replacing the module fixes the issue as I dont think its module because it just wont heat and everything else works fine
The dryer has started making a funny noise like something is thumping inside it....sometimes the pattern is regular and sometimes it is a bit erratic. It makes the noise even if nothing is in the dryer...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 10, 2011 | Fisher and Paykel DEIX2 Electric Dryer
How to replace drive belt on Fisher Paykel deix2 ?
dryer runs too long doesn't seem to want to shut off automatically when clothes get dryer
Oct 30, 2010 | Fisher DEIX2 Dryer
Looking for a parts list for a Fisher Paykel DEIX2 dryers
DEIX2 - one of the heat coils remains hot after dryer stops. I can see that it is still red (hot) after dryer is turned off. I need to unplug dryer for it to go off.
Oct 14, 2010 | Fisher and Paykel DEIX2 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel DEGx1 dryer top load is only blowing cold air
Could be something simple like a limit popped due to clogged vent or a open heating element. DEGx1 Service Manual
Jul 22, 2010 | Fisher and Paykel DEIX2 Electric Dryer
Do the Fisher Paykel Dryers DGGX1 take twice the drying time of a normal (Kenmore) dryer to dry cloths? I put in a load of towels and after an hour and a half they still weren't dry. My other dryer would...
make sure there is no lint build up inside the round housing where your lint trap goes. the holes in the housing sometimes plug up and you can't see it. one screw at the bottom and rotae slightly to remove. also make sure vent is clear
Jun 26, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Fisher Paykel Dryer is taking 3 hours to dry(DeIX2)
Check your cvent going outside. also check to see if the vent is smashed. try using the time dry cycle and see how your clothes turn out. if they are still wet or damp. you have a heating problem. try those solutions.
Oct 19, 2009 | Dryers
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Fisher & Paykel DEIX2 Online repair manual?
I couldn't find one either. I would like to know what the different codes mean. Can anyone help?
Apr 01, 2008 | Fisher DEIX2 Dryer
Dryers Logo
201 people viewed this question
Top Dryers Experts
