Question about Sharp AR-5316 Advanced Digital Imager Copier
E-7 sub code 10
I am using Sharp-AR5316 and facing the problem that Code E-7 and sub code 10 apearing what to do to sart machine
  • Tim Babcock
    Tim Babcock May 11, 2010
    Usually that has to do with the scanning and the optics. Do you hear any clicking noise when the machine starts up?
  • 24 Answers
Check connection of the ccd cable to the ccd and the pcu board, if all good the you have problems. try reseting the m/c first
Posted on Sep 05, 2008
H3 code in sharp ar5316
It sound like you have a thermistor that either has a buildup on it or it is not contacting the fuser roller. I would remove the fuser, disassy and clean every component. Reinstall and usually the problems go away. Let me know if you need more assistance.
May 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar5316 code U2
Try reset code sim 16 in diagnostics.
Type p * c * machine will go into sim mode
type in 16 then start.
press CA
machine will turn off then back on.
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Delet code
It's an calibration error caused in the optics section. Make sure there is nothing on the scanner glass but the cover itself. Turn the power off, wait 30 seconds and turn the power back on again.
Do you hear any grinding noises when the machine is initializing?
Aug 08, 2008 | Sharp AR-5316 Advanced Digital Imager...
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
May 07, 2008 | Sharp AL-1641CS Color Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
