Question about Kitchen Ranges
Wondering what the f9 code for a fridgidare drop in range
  • 4,323 Answers
Hi
F9 error code in your Frigidaire means "Maximum oven door lock time exceeded", it appears when it's trying to lock the door but is not aware of the time to stop. You will have to check the door switch and door lock's motor and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 01, 2011
On my new stove i got a F9 code what can i do to get my stove to work
Possibly incorrectly wired. Often these codes are make specific.
F9 or F9 E0 - Whirlpool Home Appliances - Whirlpool® product help
producthelp.whirlpool.com/...Guides/...Ranges/...Code%2C...Code.../F9_or_F9_E0
Apr 22, 2017 - Reset power to the product: This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection. If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply. During a power ...
What does the F9 error code mean on my Kenmore range Model 790 ...
https://www.shopyourway.com/questions/1074065 Apr 6, 2010 - Door locked started blinking, door never locked,..pressed clear button caused "dr" code, pressed clear again and "f9" and beeping occurred. ... This was extraordinarily helpful...we got this oven from my mom in law when our old one died and she bought a new one, we knew nothing about it but thanks to ... How do I get rid of F9 error code on range?
18 Dec 2011
Why does my Kenmore oven display the F9 error code ...
1 answer
29 Oct 2009
How do I reset an F9 on Frigidaire oven?
1 answer
26 Oct 2009
What does the error code F9 mean on my Maytag ...
1 answer
11 May 2008
More results from www.shopyourway.com
going to clean the oven but got a f9 error had to reset it for it to work ...
? 1:49
https://www.youtube.com/watch?v=cgGKxTxxf4E May 17, 2016 - Uploaded by mike webb
going to clean the oven but got a f9 error had to reset it for it to work mike webb po box 408 stryker ohio 43557.
F9 Error Code - Whirlpool , KitchenAid & Kenmore Range - Repair ...
? 1:01
https://www.youtube.com/watch?v=MXMDjZRNDnw Oct 31, 2014 - Uploaded by ApplianceVideo.com
Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos brought to you by ...
stove got F9 code Google Search
Mar 18, 2018 | Kitchen Ranges
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
F9 whirpool range
I had a power fail & when the power came back on I had the F9 error code on my range with a beep beeping that would not stop until I pressed cancel, beeping stop however F9 error code stayed on, I solved the problem by turning off the power, then turning power on again and then I pressed start button and it removed the F9 error code and all is working GREAT now...
whzurdaddy...
Feb 26, 2012 | Whirlpool Kitchen Ranges
Maytag range fault code F92
There should be some number after the F 9 Error code. And, it would look like this
F9-1 Latch lock upper
F9-2 Latch unlock upper
F9-3 Latch lock lower
F9-5 Latch unlock lower
F9-6 Latch both lower
This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK IN.
Jan 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How to cancel f9 code
JennAir F code 9
F9 Door lock safety circuit on power relay board sensed Replace power relay board
Nov 10, 2009 | Kitchen Ranges
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
