Question about Samsung Dryers
We just installed a new Samsung washer/dryer....on the spin cycle it starts to shake really bad and moves the machine 5 inches or more. did something come off balance installing this?
  • 415 Answers
Did you remove the shipping bolts for a frontloading washer located in the rear refer to your installation manual...
Posted on Apr 01, 2011
SHAKING WASHER
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
While replacing motor coupling and vigorously moving motor gearbox around, something dropping on the base of drum but could not see what it was. And after completing the motor coupling job , I set the...
those pins are not important they are there for transportation purposes such as moving from one home to another or country don't worry about them. As far as the shaking and walking use a level and level your machine in both directions.
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer is shaking violently when it is time for the spin cycle
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Dryers Logo
852 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
