Set turns on with audio then shuts off after a few seconds. no picture.
  • davebenner Apr 02, 2011
    SONY PLASMA KE37XS910
  • 760 Answers
Please include make and model of your set. This will help in diagnosing your problem.
Posted on Apr 01, 2011
  • David Duncan
    David Duncan Apr 05, 2011
    When your set shuts off, do you have a blinking light in the front? If so, how many time dose it flash, before starting another sequence?
Kodak digital frame shuts off after 5 to 15 seconds
This sounds like a setting issue on the photo frame. You should check for a timer for screen time on the frames menu.
Jan 02, 2014 | Photography
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
When tv is turned on you can only hear the audio and no picture. It shuts off after 10 seconds
When tv is turned on you can only hear the audio and no picture. It shut off after 10 seconds
Sep 06, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
Turn set on picture for a few seconds then it
Check to see if you are getting 12vdc feeding the T-CON board. the gray glowing means the backlight is working.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 03, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
Screen goes green then black
That model is famous for bad picture tubes, and thats the classic symptom of a bad tube shutting the set down
Jun 25, 2009 | Sony KP-51WS500 51" Rear Projection...
50" Plasma turns off and back on without picture; audio stays on
Yes, you are correct. there are a few component issues on the power circuit board that will need to be replaced. the mani component will be the capacitors and transistors.if not repaired soon, this unit will completely stop working.
Mar 11, 2009 | Mitsubishi PD-5030 50 in. HDTV Plasma...
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | RCA P46921 46" Rear Projection Television
No picture
Hello pravinp,
Since this is a DLP set, The bulb becomes suspect. I would take the bulb out and measure the voltage in the socket from which the bulb was taken to determine if the socket is hot. If it is I would then take a resistance reading of the bulb, the resistance should be at 0 ohms. If your bulb is blown replace it with the exact type. The TV might be shutting down to prevent further damage from occurring
I hope this helps
Shuttle83
Dec 21, 2007 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
