Question about Regal Ware K6725 Kitchen Pro Bread Maker
I got this bread maker from another lady,it has only one little beater in it, like a half of a fan blade. I would like to know is there other beaters that goes with it. An what can I make with this beater? And is this a good bread maker? thank you for your help. Ethel
    Genius:
  • Regal Ware Master
  • 1,280 Answers
That's all you need. The beater or paddle has only one arm.
Posted on Apr 02, 2011
I need a beater for my breadman
Did you ever find a paddle for your TR444?
Nov 03, 2012 | Breadman Bread Machine Paddle Blade Tr444...
First time using bread dough beater It was hard to put on and am unable to remove
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
Why is the beater scraping the cooling drum?
Check drive shaft alignment,bent beater assy and scrapper blades.
Dec 04, 2010 | Taylor 632-33 Ice Cream Maker
I need beater with its blade and a pipe for taylor machine
you can call Rick at Restaurant Parts and More, 1-888-814-1110. Have you model and serial numbers. He can most likely help you.
Apr 14, 2010 | Taylor 632-33 Ice Cream Maker
Beater too low-will not lock
I would check the bottom of the beater blades to see if they are out of shape.,or is the base of the mixer raised somehow to cause this problem
Jul 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchen Appliances - Others Logo
26 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Ruth summersides
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
