Question about HP Office Equipment & Supplies
Checked print cartridge but still flashing error
  • 1 more comment
  • lt1968 Aug 05, 2008
    hp psc 1410 orange light flashing check print cartridge E lite up in copies cartridges are new
  • scsrm123 Aug 14, 2008
    I am new cartridges added then orange color light is blink
    check print cartridges how to sovle the problem
  • parkerguy May 11, 2010
    Flashing what error. If its a 10.10 error, press the check button and wait 30 to 45 seconds for it to come to ready.
  • 138 Answers
I am assumming both new cartridge seal tapes have been removed. I know it sounds like I'm being rediculous but you'd be amazed how may we get into the shop each week that this is the problem. :)
There is a known issue in this model and similar printers that causes a lot of them to fail. A spring tension wire that holds the cartridge in place in the cartridge housing breaks out of its clips where it hinges. If left unchecked it causes the wire to move back and puncture the flex cable that makes contact with the cartridge. There's a photo below that shows the wire broken loose and a photo that shows the resulting damage when left unchecked. If this is the issue, unfortunately the printer is not repairable as the parts aren't sold by HP.
Hope this helps you. If not conntact me back and I'll try and walk you through a couple other things to check.
Posted on Sep 03, 2008
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
My 5500 all in one printer is flashing print
check if the cartridge is not empty or the nozzles of the cartridge is not blocked. if so replace the cartridge and then try to print
Apr 16, 2010 | Computers & Internet
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Error 1203
    hi..
    error 1203 means either or both cartridges have short circuited and needs replacement..
    You will need to perform the following steps to find out which cartridge is defective:
    1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
    2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
    3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
    1. Make sure the printer is in “Copy Mode.”
    2. Press the “Menu” button once.
    3. The screen will display “Copy Menu: Copies”.
    4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
    5. Press the check button once. The screen with read “Tools: Maintenance”.
    6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
    7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
    8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
    If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
    1. Turn the power OFF.
    2. Open the front cover.
    3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
    4. Reseat both cartridges in the printer and check for the error.
    5. If the error still displays, then remove the color print cartridge.
    6. Close the cover.
    7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
    8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
    9. Remove the black print cartridge and reinsert the color cartridge.
    10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
    11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
    Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Printer light blinking
    Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
    Product
    --> Lexmark Z615 Country / Region:
    Country / Region:
    --> United States Language:
    --> Language:
    English Need to download
    a driver?
    --> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
    1. First count the number of times the light on the front of your printer flashes.
    2. Then refer to the table below for information about the error condition and recommended recovery procedures.
      Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
      The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
      4 Print Incomplete:
      The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
      12 Cartridge Short:
      The printer has detected a short circuit in a cartridge.
      1. Turn the printer off.
      3. Turn the printer back on.
      4. Remove the color cartridge.
      5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
      6. Remove the black cartridge and then reinsert the color cartridge.
      7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
      8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
    Apr 22, 2009 | Lexmark Z640 InkJet Printer
    Problem on a canon 3100
    The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
    Two orange flashes: Out of paper, paper jam, or paper feed error
    If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
    Three orange flashes: Paper jam
    If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
    Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
    Replace the empty BJ tank and press the Resume button to continue printing.
    Five orange flashes: BJ cartridge is not installed properly
    Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
    Six orange flashes: BJ cartridge (printhead) is not installed
    Seven orange flashes: BJ cartridge (printhead) is defective
    Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
    Eight orange flashes: Waste ink absorber almost full
    The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
    The POWER light flashes orange and green alternately: Service error
    A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
    Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
    4. If it does not, close and reopen the cover:
    5. Remove the color print cartridge.
    6. Close the cover.
    Dec 01, 2008 | Lexmark Office Equipment & Supplies
    Light Keeps Flashing
    Hi pmerriwether
    One of your cartridges have a problem (is empty)
    If you have replaced the black cartridge and still get the error replace the color cartridge aswell.
    Regards
    Go-Tech
    Aug 06, 2008 | HP DeskJet 694c InkJet Printer
    Printer ripair
    The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
    Feb 20, 2007 | Canon BJC 3000 InkJet Printer
    941 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
