No manual to tell me how to turn on the flame. I see there is a panal that when opened reveals a dial and two switches. The one switch turn on the heat (increases and decreases with dial) and the other turns on the fan. There is no flame. Please advise if I am missing a step to turn on flame or if bulb is burnt out how do I fix it and what type of bulb is needed. Andrea
    Brigadier General:
  • 4,736 Answers
Andrea, it would be a real help to know who the manufacturer is and the model number of your electric fireplace.
Posted on Apr 01, 2011
How to light grill
switch the dial to the indicator which shows the top grill,usually this is a black line with a squiggle under it.
Sep 15, 2016 | Ovens
Heater not working but flame effect does
If you have opened the glass door you will see 2 switches and a rotating dial, thermostat. ! switch is heat, the 2nd is the flame effect. it is not serviceable to a consumer unless professionally trained.
Apr 28, 2016 | Dimplex DS5603 Heater
How to wire front panal
You will need to open the computer case and check that the cables that run from the actual power button to the motherboard are plugged into the proper spot on the motherboard. Sometimes reseating the cable can fix this issue.
I think this is the link to your motherboard documentation: http://www.via.com.tw/download/mainboards/3/4/p4mapro533_r100.pdf
Check the page 2-14 or 2-15 and see if that helps you to identify the actual connection for your power switch.
Nov 14, 2011 | VIA P4MA Pro Motherboard
I need instructions on how to set my Grasslin Intermatic FM1 STUZH 120 timer
Open following links for analog timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
FM1STUZH-120 is 120Volt 24 hour timer with manual override button.
Each tripper-or-pin on timer dial represents 15 minutes.
The timer can be set for several different purposes.
Since the timer has manual override and NO NC terminals, the best way to proceed is to wire your timer, turn power ON, move 10 trippers-or-pins outward, leave rest of pins inward, then manually rotate dial to watch when load turns on-off. Then move override switch to each of 3 positions and repeat same test.
These actions will reveal correct wiring and switch setting for your purpose.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
I have a carrier furnace and the led light is blinking 3 short then three long what is the code
code 33 LIMIT OR FLAME ROLL-OUT SWITCH IS OPEN - If open longer than three
minutes, code changes to #13. Flame roll-out switch requires manual reset.
Check for: - Dirty filter or restricted duct system. - Loose blower wheel.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch or fuse link open).
- Open Flame Roll-out switch, or fuse link. Manual reset or replace.
Apr 19, 2011 | Carrier 38BRC036 Air Conditioner
Which is the on position?
You posted under Woods 59382
Open following link to identify timer for sure and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
To check switch setting and segment settings, plug timer into outlet, turn lamp on, plug lamp into timer, then manually rotate timer dial clockwise to check operation.
Change the switch, and rotate dial again to see when lamp turns on-off.
After segments and switch are set how you want, then rotate dial until current time lines up with arrowhead located on inner dial.
Analog timers like 59382 have small motor that rotates clock dial just like old fashioned clock.
As dial rotates, segments on dial move lever that opens and closes circuit to lamp.
The switch, or override button, lets you choose if you want timer program to operate, or if you want lamp ON all the time.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 16, 2011 | Woods 59382 15Amp 3Prong Outdoor Heavy...
Can't set timer
You posted under Grasslin in-wall mechanical timer.
Instructions for this timer are nearly identical to GE
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
First, the timer has to be wired correctly, so review wiring instructions shown on link above.
Next, the pins have to be set, so read instructions and look at image of pins shown on link above.
Last, the timer switch has to me set. I believe timer switch is moved all the way right for timer program to operate.
To check operation, manually rotate dial clockwise to watch lights turn on-off.
This will tell you exactly how to set pins and switch.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins trip a lever that opens and closes switch to your lights.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 08, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
How do I work this timer? Model 59200. Does it work on any kind of lamp? Do I turn the lamp on? Tried it and didn't work, never turned the lamp off. Manual sheet not much help. Thanks for more info. Rita
Open following link to identify timer and see manual plus written programming steps:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Lamp must be turned ON, and Bulb is good.
Raise and lower a few segments on the timer.
Plug timer into wall, and plug lamp into timer.
Manually rotate timer dial clockwise to watch lamp turn on-off.
Notice also that timer has switch located on top.
Move switch into one position and manually rotate dial again.
Move switch to other position and manually rotate dial again.
This will tell you how to set timer switch and segments.
To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and segments click a switch back and forth that turns circuit on-off.
Feb 07, 2011 | Woods 59200 Lamp and Appliance Timer with...
Igniter does not turn on
need more info....Remove the front panel and look for a sticker that will tell you what the Diagnostic flash codes are...3 . 4 . 5....etc...I service many funaces and cant memorize all the codes..lol...we always need the \manual....What does the furnace do??...Turn the power off (after you observe the code)...then turn it back on with a call for heat....What happens????The exhaust fan starts......then the ignitor starts glowing....etc.////this info is more important than flashing codes
Oct 31, 2009 | Goodman GMS90703BXA Heater
1986 Weathermaker SX 150 series, model S85X060-CC-1
There are 4 -steps for full run time to kick in a furnace.. step-1, inducer fan runs & prove thru the air tube which closes a switch and tell the circuit board to go to step-2, the igniter lights the pilot & prove its lit by heating the thermocouple, which tells the circuit board to go to step-3, opens the gas valve to dump gas in, which will light from the pilot light, and prove by a flame sensor metal stick on the last burner , which heats up and tell the circuit board Saying, ok , I've got flame.. step-4. when the box heats up, it closes a switch and turn on the main fan...! (Some gas-valves has a brain -or circuit board on top of them and are real sensetive to moisture..)
Sep 05, 2008 | Heating & Cooling
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
