Question about Nintendo Wii Console
I have direct tv and I am trying to hook my wii up so I can watch netflix it is giving me an error 51420
  • Nintendo Master
  • 441 Answers
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51420&system=Wii&locale=en_US
Posted on Apr 02, 2011
How do I get it to work on the tv in the living room with the wii hooked up in the bedroom for it
The Wii has to be hooked up to the tv you want to watch Netflix on.
It wont work from another room.
Aug 20, 2014 | Netflix
Trying to hook it with netflix keeps giving me an error code 51420
This should remove the error and allow you to watch Netflix.
Jul 23, 2011 | Nintendo Wii Console
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
Jun 22, 2011 | Nintendo Wii Console
I am trying to access the internet to get netflix on a used Wii. It is saying error code 51420. What do I do?
Sometimes this happens because servers go down for nintendo. If this problem persists it might be caused by a third party adapter that is used to connect your wii to the internet.
May 30, 2011 | Nintendo Wii Console
Hook up my wii so that i can order and watch netflix on my tv
With the Wii you can only watch Netflix movies through the instant queue. In order to do this, you must request the Netflix CD for the Wii online and write down the code that is given to you when you do so. When the CD arrives, put it into the Wii (Make sure you have a working wireless connection to the Wii) and enter the code you wrote down. You should be good to watch any movies through the Netflix instant queue on your Wii. The Nintendo Wii cannot otherwise play DvDs. Anytime you want to use Netflix on your Wii, you must insert the Netflix CD for the Wii, so be sure to keep track of it! Let me know if you need anything else!
May 18, 2011 | Video Game Consoles & Games
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
Can,t hook up to internet to watch netflix it says error code 51330 need your help thanks.
I had that problem also, it is a problem with the router and wii connection, this web site helped.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
. I am giving you the website instead of directions because I don't know what brand router you have. Hope this
helps.
Mar 07, 2011 | Nintendo Wii Console
We hooked up to new internet service and now can not connect to netflix. We do not know our pin number.
wii generate lot of network errors ........ so don't worry, you can solve this easily ..... i got some problem with my wii and its resolved by the help of Repair Guide
it covers network problems thoroughly so check this out !!
it will definitely helps you
CLICK HERE
Dec 29, 2010 | Nintendo Wii Console
Wii Console: error code 51420...
May 17, 2010 | Nintendo Wii Console
Error code 51420-- wii is hooked via usb to modem and unable to connect
This is directly from the Nintendo Tech Support Site
  1. If your connection worked previously, check to see if thereis a Wii System Update that you have not aquired. To get the latest WiiSystem Update:
  3. Check to make sure you are not running the Wii LAN Adapterfrom a USB hub (a device that connects multiple USB products through asingle device), as this will likely not work. Connect the USB Connectordirectly to the modem or router.
  6. Ifpossible, try another Wii LAN Adapter. If you are unable to try anotherWii LAN Adapter, or are still receiving this error code, please call1-800-255-3700 for assistance.
If you need step by step instructions on how to set up the Wii LAN, click this link
Installing the Wii LAN Adapter
Dec 08, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
126 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
