Question about Sony KP-51WS500 51" Rear Projection Television
There are 3 separate images on the screen - Sony KP-51WS500 51" Rear Projection Television
  • Sony Master
  • 8,617 Answers
Thats caused by failed convergence ICs and pico fuses. You can get the Sony type 1 convergence repair kit from www.tvrepairworld.com the kit contains the ICs and Picos plus the CD with repair instructions.
Posted on Apr 02, 2011
Dell flat screen monitor is repeating images
"Shadowing" effect fixed by separating the wires in back. Touching wires cause crosstalk of signals . Immediate fix.
Aug 01, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
Samsung monitor 204b screen image is split in to two parts; the upper part OK but lower part is gibberish, ghosty?
Interference. Separate the wiring so it doesn't touch. Touching wires create cross-talk of signals and keeps from running normal.
Feb 11, 2014 | Samsung Computers & Internet
Screen splits into 3 separate images not convergence
Make sure you re-adjust convergence in HD and non HD modes if your TV has HD
Mar 30, 2013 | RCA HD52W59 HDTV Projection Television
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
No image on screen
Install a working videocard in pci slot to test , if it works replace old one, if it's embeded in the motherboard install separate videocard.
Feb 23, 2010 | Computers & Internet
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Red and green have separated. is this fixable?
yes this can be fixed
it is the convergence IC's that controls each color image alignment ,also other components(resistors , diodes , capacitors , ect..) in circuit with these convergence IC's(STK's) also need testing to see what other component has also failed or needs replacing.
Mar 19, 2009 | Zenith R57W46 57" Rear Projection...
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
18 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
