Question about Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder
Don't know if battery is dead. looking for a service center that makes house calls.
  • 692 Answers
Call Roadrunner Mobility @ 1-800-467-2668 Excellent Repair Service They will make house calls and leave you a loaner to use while they check out your chair Hope this helps
Posted on Apr 01, 2011
Car wont start
Check the fuel. Don't rely on your gauge, and if in doubt add some fuel just to make sure there is enough to start the car. Try to start the car and if it still doesn't start you know that fuel isn't the problem.
Make sure your car is in Park and the emergency brake is set.
Look closely at your dash board when you attempt to start the car. If your lighted panels don't come on or are very dim then it is likely that you are dealing with a dead battery. Either use a battery tester or simply hook the battery up to a charger or use jumper cables to hook up to another car battery in order to charge the battery enough to start the car. After you charge the battery if your car still won't start you may be dealing with a bad starter.
Call a mechanic to find out if there are any other possibilities before you purchase and replace the starter.
Mercedes Custom parts
Jun 06, 2012 | 2001 Oldsmobile Alero
Tip
What To Do When Your Phone Does Not Turn On
The simplest reason causing a phone not turn on is a dead or drained battery. It happens when the phone gets immersed in water, dropped or allowed to fully drain the battery. The symptom is phone not turning on and not charging the battery. When that happens, make sure first that the battery is not just dead or drained before you send the phone to the service center for repair or before you buy a new battery. You may decide to send it right away only to find out the battery is simply dead/drained or buy a new battery only to find out the phone is dead.
The first thing you can do is borrow a friend’s known good battery similar to yours and try it in your phone. If the phone turns on, you are pretty sure your battery is dead or drained; otherwise, it's time to send it for repair.
When it is verified that the battery is dead or drained or if you don’t have someone to borrow from, try to revive the battery before you buy a new one. You just need a 9-volt battery, a 6-12 volt power supply, or a DC adaptor (6 or 9 volts) and a set of wires.
Connect the set of wires to the terminals of the 9-volt battery, power supply, or DC adaptor whichever is available.
Look for the polarity markings on your battery and connect the other ends of the wires to the battery terminals in the same polarity as the source above. The positive terminal is marked (+) while the negative is marked (-). Do this for 10 to 60 seconds or until the battery gets slightly warm. Do not use this procedure to fully charge the battery.
Insert the revived battery in your phone and charge it until it is fully charged. If the battery works well and does not discharge easily, you don't have to replace it.
In the event that it is not verified whether the phone still turns on or not using a known good battery and the battery is revived but the phone is still not charging the battery, the phone is dead; send it to the service center for repair.
on Dec 06, 2009 | Cell Phones
Looking for manual or information my 1988 TravelAire Camper van. It is on a Ford e-250 chassis. Need to know how the 120 Volt system works; i.e. does it operate all lights (including 12 volt); does it...
Typically, the 110 Volt will go into a power center which should include a small amp battery recharger. Your 12 volt lights should run off a 'house' battery which should be isolated from the truck battery, yet, the truck alternator should charge the "house" battery on the road. The device that allows this is called a Isolator. You may find a manual switch instead. You definitely don't want the house and truck battery to both run yourf coach with no recharge capability. Some systems have a 'emergency start" switch which allows you to use the house battery to start the engine. All 12 volt house stuff should run off the house battery and the battery should be recharged by the truck or the small battery charger. Do you have an evap frig? Runs on propane or electricity? It needs 12 volts whether it is running on gas or 110 Volts. The 12 volts runs the control panel and the heat to make it work is supplied by the gas or by a electric calrod if 110 is available.
I am pretty familiar with these electrical systems ... I seriously doubt you will find any information on your 20+ year old motor home. Typically, the printed specs and equipment and the data is obsolete before the ink is dry because the manufacturers use what is available as they build. If you have additional questions simply click on the "add comment" or the "reply" link and I will take a look-see.
I hope this answers your current question. Thanks for your interest in FixYa.com
Sep 07, 2011 | Ford E-250 Cars & Trucks
The Ritz Camera store looked quickly at my Pentax ist DL digital camera and said the sensor was dead. It would cost$400. to repair. Is that the only reason I would be getting a black image when taking a...
Yes. The CCD chip has died and they don't tend to be cheap, but I would call around to other service centers before giving up hope. $400 seems a little steep to me, but I don't often work with Pentax units, and haven't priced their CCDs recently.
Jun 27, 2011 | Pentax *ist DL Digital Camera
I have a 1998 mercedez c280 with a dead battery. I am unable to get into the trunk with the switch or my key
Mercedes Benz is the most service oriented company in the business. Whether you are the original owner or a secondary owner give the local Mercedes Dealer a call and they will dispatch a truck with a technician immediately. More than likely there will be no charge.
I know the same thing happened to me with a dead battery. Don Rasmussen is absolutely unbelievable locally. I couldn't believe the no charge. The Tech stated " That's the service you paid for".
Best regards,
TF
Jun 03, 2011 | Mercedes-Benz C-Class Cars & Trucks
Dogs chewed up wiring from house to outside ac don't know what goes where
Wires used in AC for power are of different color like red for (+) black for (-) and green for (N). You can slice the rubber (about half inch) ends of broken wires and then reattach them matching the color, like red to red, black to black and so on. After that apply insulation tape on the joints. Make sure you switch off the power before you do all this work. If you are unsure, please call the AC service center and they will send an electrician to fix this.
May 13, 2011 | Heating & Cooling
We don;t have a dial tone and can't call out. Can you help ?
if you have a normal phone line. your problem can only be in a couple of places unless your batteries are dead in the phone. Your inside line(check) and the outside line going into the house(check)
Kdog
Dec 29, 2010 | Lands Phones
My 2007 dodge caliber battery went dead, no warning, is this normal? shoud a light go on to show my battery is waring low on the dash? Where should I purchase my battery and do I need to purchase a...
Hi...Battery problem on your Dodge ..First check your cable on your battery see if they are not loose on the battery' post, then try to start if not.. recharge your battery for 8 hours , put a good temporary battery on your van then start your engine then unplug your positive cable on the positive battery post, see if the engine still running. if the engine stop your alternator fail to charge.. then you replace it.. look on any second hand garage for a good battery between $20 to $60 dollars for use one ...unless you prefer by new the it will be between $90 to $160 good luck
Oct 18, 2010 | 2007 Dodge Caliber SRT4 Hatchback
SONY VAIO VGN-NR11S SERVICE MANUAL require to replace the casing
as far as i know. they only replace casing/housing thru their repair center
but just to make sure, you can call their parts center department
1-800-488-SONY (7669)
sony.parts.com
Mar 13, 2010 | Sony Vaio VGN-NR110E/S Notebook
My O2 samsung phone has suddenly stopped receiving txts and calls.my friend tried to ring me and it just went to voicemail. my signal bar is full and so is my battery. i tried taking the battery out and...
if you can still dial someone, but can`t receive anything, try dial ##002# , then ask someone to call you. for the txt verify the sms center number, if you don`t know it call customer service
Nov 11, 2009 | Verizon Communications Samsung Alias Cell...
Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder Logo
79 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
