Question about Beko Dishwashers
New dishwasher (Beko 2542F slimline model). Put it on for 1st time last night -when I got up this morning, the cycle which should have taken just over 2 hours hadn't finished. There's soapy water in the bottom of the machine which hasn't drained and the "wash" light is still on. Looks like the dishes are clean but hasn't moved onto the rinse/dry part. Followed instruction in manual to drain it (hold start stop button till lights flash and should drain in 45 sec) but nothing happened.
Rotu
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
  • 833 Answers
SOURCE: ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Posted on Dec 11, 2007
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
Beko 450 dishwasher not filling up
normally there is a water censor that is in the back of the machine you will need to remove the back and look for a small pipe 5mm diameter going upwards remove it blow gently into it you should hear a click and one when you release the air, if so then the switch is ok but the small metal or plastic pipe where it came from was blocked unblock the pipe return then pipe back to its position and the problem should be gone only attempt this if you are competent and get a friend to help eric
Dec 25, 2017 | Beko Dishwashers
I have a slimline beko dishwasher. The control panel is stuck on a cold wash and we can't budge it. Model is dw450. Any ideas how to fix it or how to get at electrics to fix it?
The programmer is accessed by taking the front panel off, and loosening the door front. If it won't move either way it is faulty.
Apr 14, 2012 | Refrigerators
I have a 2 week old Beko dishwasher and last night I noticed that the lights were all flashing, I switched off and opened the door and the bottom of the machine is full of water. Any ideas?
Either there is a leak activating the error alert or there is some blockage from the drain hose to the food dispenser.
Unplug the power cord for 24 hour to reset the disrupted logic back to the original stage to see it it help. If the manual shows the diagnostic mode, try to set to manually drain so a new cycle can be started to test.
May 06, 2010 | Dishwashers
I have a Beko DE 2541F Slimline Dishwasher and it fills and empties the water but the cycle does not start. The water does not get to the spray arms. I have tried on pre wash cycle as well so I do not...
If there are no problems of drain valve stuck, then the problem with the micro controller board.
When the water is full in the tank, the wash cycle will start with the spray arm in action. Lastly block the drain hose and see. Here water full will be detected & the machine will start if the level sensor is OK .
If m/c works here, you have to check the Solinoid valve of the drain.
Otherwise the micro controller.
For this pl take the help of the service provider as lot of programming versions are there. Some may suit or may not. If we try the will not accept after selling the board to u.
Apr 07, 2010 | Beko 24 in. D3731F Free-standing...
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Jun 29, 2009 | Beko 24 in. D3421F Free-standing...
Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Kenmore dishwasher
could be eithe depending on which one u have model and make helps
Oct 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
63 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
