Question about KitchenAid KUDR01TJ Dishwasher
Water does not drain from diswasher - KitchenAid KUDR01TJ Dishwasher
  • 2,510 Answers
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Apr 01, 2011
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
Water doesn't drain from my dacor diswasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 23, 2011 | Dacor Epicure ED24 Stainless Steel Builtin...
The water is not draining at the end of the dry cycle. White dirty water pools in the bottom of the diswasher.
heatman101
Feb 02, 2011 | Dishwashers
Fridgeadare FDB510LCS5-My diswasher does not appear to be draining. The bottom of the diswasher is full of water.
there is only a few things this could be caused by
if it is not obvious like a clear plastic wrap covering the drain ports on the base insdie teh dish washer then it will have to be one of the following:
check these:
1. Drain line/air gap
2. Pump
3. Drain valve and/or solenoid
4. Belt
5. Motor
6. Timer it is highly not likely to be the timer..
GL
Jan 02, 2011 | Dishwashers
Miele Incognito G843SCVi Plus diswasher will not drain
if the timer is in good condition (no wires burned off)  then it must be the pump itself that need replacing  dishwashers need the drain hose to rise to the counter and then fall again to siphon and make the pump work easier  also it helps keep water in it to stop the plastic parts in it from overheating    if the hose doesn't rise and fall  it may have led to your failure
Nov 07, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
Water still running with buttons off and door open
indicates that the water solenoid diaphragm has failed and not shutting of the water supply
get a new one from the service agent or have a technician come , diagnose and replace the faulty item
Sep 08, 2017 | Dishwashers
Diswasher
You will have to test the solonoid electrically now its probably getting juice and the solonoid may have failed. You can get just the solonoid ot the entire pump assy for a little more.
Oct 01, 2007 | Dishwashers
KitchenAid KUDR01TJ Dishwasher Logo
55 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
