My Altec Lansing BX1021 Makes static noises when wires moved, but no sound from computer.
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 01, 2011
Why does it emit a loud whistle when turned on?
I got rid of my Altec Lansing because I got white noise when the unit was turned OFF. They are not a good make. You can try moving any wires or magnetic influence away from them. I now own Bowers and Wilkins MM1 speakers which are amazing.
Bowers Wilkins MM 1
Mar 14, 2016 | Altec Lansing New Original Dell ADA995 5.1...
Altec Lansing BX1021 system. Why does it make a low humming-like sound when the bass is turned up and it doesn't go away?
Usually when you get a low level hum it is because something isn't grounded properly thru the shield on the connecting cables. Try removing them one at a time to see which one makes the hum go away.
May 01, 2017 | Altec Lansing BX1021 2 Speakers
What can I do to get my speaker to turn on?
make sure they are plugged into a power source and they u push the power button to on, make sure the volume is turned up and that your computer is not muted and producing sound
Sep 04, 2012 | Altec Lansing BX1021 2 Speakers
Right speaker is not working
hi there most of the time we found the speaker jack is faulty. But try to give a look on the right Speaker's cord connection and make sure that is connected.
Jan 22, 2011 | Altec Lansing BX1021 2 Speakers
I need to know the type of audio cable to use with the Altec Lansing BX1021 2 speaker system.
COAXIAL DIGITAL JACKS;
{COLOR OF RCA COAXIAL CABLE CAN BE DECEIVING THIS CABLE CAN BE A BLACK, ORANGE, ETC.} IT'S BASICALLY COAXIAL -- OUT & IN..
http://www.crutchfield.com/S-S7N8XMJitvh/learn/learningcenter/home/connections_glossary.html
**ABOVE IS THE URL ADDRESS WHERE I FOUND THIS INFORMATION COPY AND PASTE TO YOUR URL BAR AND DISCOVER THE WORLD WIDE WEB
This type of jack is used for the digital audio inputs and/or outputs on A/V components such as receivers, CD players, DVD players, and more. Coaxial digital jacks are also sometimes found on higher-end PC soundcards for digital audio input and output.
Coaxial digital inputs and outputs use standard RCA-type jacks (so coaxial digital cables are terminated with standard RCA connectors). But the cable itself is specially designed to handle the much wider frequency bandwidth of digital signals
**** ~ Where did I find this information here is the URL Address where this information was found. ~ ****
Dec 07, 2010 | Altec Lansing BX1021 2 Speakers
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Static but no music from the satelite trebble speaker
Try to reconnect all the wires, the problem seems to be with connection. Instead of spending lot of money on speakers, you can buy just the wires, they are pretty cheap. Hope this helps.
Jul 25, 2009 | Altec Lansing VS4121 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Disturbance in audio when i increase d volume
do you have wireless?, this could be affecting your sound, also check your hardware compatability and make sure everything is good 2 go.
Oct 03, 2008 | Altec Lansing Audio Players & Recorders
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
