Question about Fujitsu Siemens ESPRIMO MOBILE V5535 Laptop Universal AC Adapter 18-20v (AC22VPNVK5EA7)
How do I unlock num lock on my fujitsu U9200 ?
How to unlock my Huawei U9200. Cant remember google acc. What and how to repair software please?
is it network locked? If so then you need to unlock it from shop or online webstore. Its a paid service.
I recommend: http://www.guaranteedunlock.com/Huawei_Unlocking
or contact their support e-mail if listing unavailable.Goodluck!!
They are reliable and professional.
Mar 15, 2013 | Sony Ericsson XPERIA X10 Cell Phone
Unlock huawei u9200 for free
Dear, there are free codes available online. Don't ever use them beacuse this codes are given by spammers so that after
several tries your phone will be permanently locked and even your phone may be damaged and you will be bound to buy codes
or loose your phone.I faced the problem before.
You can consult with www.guaranteedunlock.com, they helped me out,i trust them.
Dec 27, 2012 | Nokia Cell Phones
For some reason the number lock is on my keyboard - i can*t figure out howto unlock it. i have to keep the fn key down in order to type the letters on the right hand side. how do i unlock/ thanks in...
Please follow the below instruction to fix your problem.
Press 2 keys at the same time: "FN" (next to the CTRL key, lower-left of the keyboard) and "num lk", which is the upper-right of the keyboard (it is on the same key as "scroll", and is next to "F12"). This will either turn on or turn off the "Num Lock" function. Both the "FN" and "num lk" are enclosed in a small rectangle. They are easy to see.
Hope the above information will be helpful to you. Thank you. Have a good day.
Aug 11, 2011 | Fujitsu Computers & Internet
My keyboard types numbers for several keys unless i hold down the function key. how do i turn off this feature/
Sounds like Num lock has been turned.
Looks for num lock on the keyboard and press it.
You may have to press FN & Numlock.
This will resolve the issue.
Apr 26, 2011 | Fujitsu Siemens Fujitsu Lifebook P7230...
My fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Fujitsu Siemens Computers & Internet
There is no num lock key on my fujitsu keyboard, however, the num lock is off. how do i turn it back on?
Check in your BIOS setting.
You may find a setting on one of the settings page for your number lock.
Nov 28, 2009 | Office Equipment & Supplies
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Keys on keyboard have locked
Try one of three keys, the num lock, the pause (break) key, and the Caps lock key.
Apr 26, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
I live in London E8 2NH and got a problem with the keyboard on my laptop Fujitsu-Siemens Amilo Pro V 2040. I strungle find a local service/repair shop.
install keybord driver properly.
if u have keybord hardware pro.then u must have to go shop.
also check tab.num lock shift caps lock not jamming.
all key check .
Oct 11, 2008 | Fujitsu Siemens Computers & Internet
Fujitsu Siemens ESPRIMO MOBILE V5535 Laptop Universal AC Adapter 18-20v (AC22VPNVK5EA7) Logo
179 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
