Question about Euro-Pro 534DX Mechanical Sewing Machine
I can't get the needle out to replace a new one, it has two needles.
  • 86 Answers
There are two little screws that you turn counter clockwise and the needle should then be easily pulled straight down. If you have problems take it to dealer for support.
Posted on Apr 02, 2011
What is "needle maintenance?"
Using correct needle for job and not bending it.
Aug 27, 2017 | Sewing Machines
Needle will not tighten
May need to replace the needle clamp and screw.
Jun 27, 2017 | Sewing Machines
Upperlooper needle is broken
do you need to find a place to get more needles?
Apr 21, 2016 | Sewing Machines
The needle broke, but now u cannot insert new needle, it hits the bottom a d would break again!
have a service done and check the needle and hook timing
it is a reason that needles hit and break
Oct 24, 2015 | Sewing Machines
Replace needle on a Huskylock 905
Look in your owner's manual for needle replacement procedure. You have to unscrew the small screw holding the needle.
Be careful that the new needle is properly seated before screwing it tight. Otherwise, you might end up with it slightly askew.
Apr 01, 2014 | Husqvarna Huskylock Computerized 905
Janome ezy lock 304 missing stitches, i have re-threaded the machine and also put in new needles?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 10, 2013 | Sewing Machines
Skipping stitches
Skipped stitches
Dec 07, 2012 | Brother XL3750 Mechanical Sewing Machine
Zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Correct needle insertion is mandatory for proper use
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
When it changes from straight stitch to sepintine and back to straight it skips lots of stitches. Just paid $300 for a new shaft.
try these suggestions & see if they help
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 15, 2011 | Baby Lock Sewing Machines
How do you change an embellisher needle
Unlike some other machines, you do not need to replace the entire needle shank when a needle breaks. The Embellisher comes with two alan key screwdrivers for changing needles. Insert the larger screwdriver at the red marking to loosen the entire needle shank. Remove the needle shank from the Embellisher and use the smaller screwdriver to loosen and remove the needle(s) you wish to change. Replace with new needle and tighten into position with small screwdriver. Then simply replace the needle shank with the red marking facing the front (towards you).
Dec 08, 2010 | Janome Sewing Machines
Euro-Pro 534DX Mechanical Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
