Question about Seth Thomas Radio Controlled Wall Clock - Wall Clocks (SET714)
How to change time on an Lorell Wall Clock? - Seth Thomas Radio Controlled Wall Clock - Wall Clocks (SET714)
How do i change time
look on the back of the clock U will see how
Mar 29, 2015 | PT Present Time Wok Time Wall Clock, Metal...
After changing battery, how do I re-set Mercedes-Benz wall clock ?
I didn't know Mercedes Benz had a wall clock. If the clock was on the wall there should be a wheel at the back, when you turn it it will change the time, if you are talking about the clock in the car then the model and year would come in handy in answering the question
Nov 18, 2014 | Mercedes-Benz Cars & Trucks
Replaced battery time will not set
place it closer to the window until it sets
Nov 27, 2013 | Lorell 60993 Radio Controlled Wall Clock
How do you change the time on vintage Syroco wall clock?
I bought a Syroco 8 day wall clock wind up with key at an auction it winds but does not make ticking sound and does not work ANY IDEAS?
Jun 13, 2012 | Watches
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at skyscaninfo.com
Apr 04, 2010 | SkyScan 86709 Atomic Wall Clock
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
I have a radio Shack Atomic Wall Clock 63-1438 and the time didn't change on Oct 31, 2009. Should it automatically change of do I have to reset the clock?
Most atomic clocks simply receive the National Institute of Standards and Technology (NIST) time signal. They do not all allow for daylight savings time changes as not all areas use it.
You will have to adjust manually.
Nov 04, 2009 | SkyScan 86709 Atomic Wall Clock
Seth Thomas Radio Controlled Wall Clock - Wall Clocks (SET714) Logo
1,196 people viewed this question
Top Seth Thomas Computers & Internet Experts
Tom Chichester
Terry
Terry
Are you a Seth Thomas Computer and Internet Expert? Answer questions, earn points and help others
