Question about Kenwood Food Mixers
My kenwood Patissier mixer stopped working. how do I disasseble the top? i would like to take a look insid.
How can I remove K beater from my Kenwood patissier which is jammed
Only a bit of CRC and some brute force is going to work. Unplug the machine. Remove the bowl, lock the head down, squirt some CRC around the top of the paddle where the shaft goes in. Get someone to hold the mixer from moving about then grip the paddle firmly with 2 hands and turn it left and right. Gradually you will begin to get increasing movement until in the end you will be able to unlock it from the shaft. Once it is off you will need to thoroughly clean the shaft then you will need to scrape out the inside of the hole in the paddle. I carefully use a small round file, I am trying to clean the hole out, not increase the size of it beyond what originally was. The hole size has become smaller over time because of flour or similar entering around the shaft during use.
Mar 01, 2015 | Kenwood Food Mixers
A901 has stopped working
Hello.
first press the boton green inside of the machine, when up the head.
if not working .
then is problems the capacitors and resistors.
Regards
Kenwood Chef Restore
Jan 06, 2009 | Kenwood KM800 Major Classic Stand Mixer
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
My kenwood mixer will not mix, the liquidiser works ok but the mixer rotates very slowly.
Hi, maybe you have 3 problems:
1 the tooth belt its nearly broken.
2 Problem in some gears
3 If its model A701/A check the back cover, and the pin in the top. its in good condition
regards
Jul 02, 2008 | Kenwood KM300 Chef Stand Mixer
Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Jun 28, 2008 | Kenwood KM305 Stand Mixer
Kenwood chef
It could be a broken drive belt, this is usually located under the top cover. You may need to remove a couple of screws to get at it. Don't forget to unplug the mixer before trying this.
Mar 18, 2008 | Food Mixers
Food Mixers Logo
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
