Question about SUPERMICRO COMPUTER Supermicro X8DTU-F Server Motherboard - Intel Chipset (MBDX8DTUF)
We just purchased Supermicro 1026T-URF SuperServer: X8DTU-F motherboard. Added Intel X25-E Extreme (Ephraim) SSDSA2SH032G1 2.5" 32GB SATA SSD drive and attached a SAS storage via Areca ARC-1880ix-12-4G PCI-Express card. The problem is - the server won't boot from CD or USB. It boots up, goes through the tests, sees the RAID on SAS storage - no errors. In BIOS it sees both the SSD and the RAID and it does see CDROM and USB drive (when inserted). After the harware check it goes to a blank black screen with the cursor blinking at the upper-left corner. SuperMicro support suggested a couple of basic solutions - like changing the boot order, but couldn't help. I have a feeling that the mother board is fine - no beeps, hardware check is fine... I night need to tweak the BIOS settings but, besides the obvious ones, I don't know which settings. Any thoughts? Thank you! Suvie55
    Champion:
  • 261 Answers
Make sure the DVD is plugged into the left most SATA connector on the motherboard. ( I-SATA0 )
Make sure SATA1 is set to "Compatability" in the BIOS.
Do not use "Enhanced" for SATA1.
Make sure the Primary IDE setting is CD/DVD in the BIOS.
Do not use "Auto"
On the USB problem, Make sure Legacy USB is disabled in the BIOS.
WARNING! The default is, Legacy USB " Enabled".
Posted on Jul 17, 2015
SATA port 0 INTEL ssd locked
Please check the solution here:
1) Find or make an XP install with SATA set to IDE mode
2) Install .NET 2.0 & Intel SSD Toolbox
3) Shut down
4) Connect up your 'bricked' Intel SSD
5) Turn on system
6) Start Intel SSD Toolbox, and the SSD should now show up
7) Start another secure erase on it, and it should go through
8) Your Intel SSD is now unlocked again
http://forum.notebookreview.com/threads/how-to-resurrect-an-intel-ssd-locked-by-the-intel-ssd-toolbox.583269
You might also want to follow this Microsoft KB - You receive Stop 0x0000007B error after you move the Windows XP system...
And for some background info - https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
Hope that helps!
Peace
Apr 20, 2015 | Acer Aspire 5610-4648 Notebook
What ssd do I buy for the acer ac700 atom?
Hi Baaz,
You would need an SSD that has a port for Serial ATA (SATA) 3 Gb/s. A faster one would do, but it will still run under 3 Gb/s. This is because the chipset on your motherboard can only prvide the max speed of 3Gb/s
For the pins, Serial ATA AKA SATA have the same ports, either SATA1,2, or 3
Hope this helps.
Jan 29, 2013 | Acer Ac700-1099 Chromebook Intel Atom...
Where is the sata connection on this board FW82801
Hi.
You won't find any SATA connectors on that motherboard because it doesn't support SATA.
Regards.
Jan 01, 2013 | Intel Desktop Board D845HV Motherboard
Does an intel 865gbf motherboard support A ssd drive
See
Intel Desktop Board D865GBF Technical product specification
Since it supports SATA drives, that includes most of the SSD products on the market.
Dec 04, 2012 | Intel D865GBF Motherboard
I have an asrock 775vm8 motherboard. Can I install a ssd drive?
Yes, your motherboard should have 2 SATA ports, however, the SSD won't perform as fast as it could in a newer motherboard. You'll also most likely require a power adapter (molex to sata).
Jan 13, 2012 | Computers & Internet
Want to change from SCSI to SATA. How can this be done?
You will need to change the backplane to a SATA type. (Fairly easy) Once done, you can change your hard drives and start using the new configuration.
Good Luck
C2Solutions
Jun 03, 2011 | SuperMicro Superserver 8052-8 (sys80528)
I was assembled a PC to edited video HD. This PC comprises: mothercard Supermicro X8DAH+, 24 GB of RAM, 2 X Xeon 5620, 1 X SSD OCZ Agility 2 3 X HDD Hitachi 1TB CD/DVD/BR LITEON ihbs112 GPU...
Remove the 3 hard drives and install Windows on the SSD. After successfully installing Windows you can add the hard drives and create your raid array later. Or even better, pick up a cheap RAID card so your CPU doesn't have to do all of the RAID controller work.
Dec 15, 2010 | SuperMicro X8DAH+F motherboard Intel 5520...
Need help on SuperMicro SuperServer 7043M-6!!
ok, all you have to do is reset CMOS. the same thing happened to me once I tried to install windows on my supermicro board. What you have to do is load the bootable CD that came with the board and follow the instructions in your book.
What happens is that windows does not have the drivers for the supermicro RAID and SATA components. The board will recognize these on it's own until you go to install windows improperly. Windows does not have the drivers for those, realizes it, and says "Windows has stopped to prevent damage" but it does it anyway. Just clear CMOS, read the book with the board on how to install an OS, and try again.
Clearing CMOS: This can be done by taking out the 3.5v watch battery you see on the board for about 5 minutes. Another and riskier way is to clear CMOS by shorting the pads. On a diagram of your board, you should see CMOS Clear. Find those two pads on you board in that general area from the diagram. You'll know you've found it because the board has CMOS Clear printed near them. Just touch them with a screwdriver for 5-10 seconds. CMOS should be clear and ready to start new.
WARNING! Be careful when clearing CMOS with the pads, if you stick the screwdriver in the wrong place, you could damage your board. Be sure to unplug your power supply before working on your machine (I'm sure you know this.) and be sure to get the correct drivers for windows this time! Oh, and rechange any settings you changed in CMOS since it has been reset to the factory defaults.
Feb 06, 2008 | SuperMicro SuperServer 7043M-6
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
See all SUPERMICRO COMPUTER Supermicro X8DTU-F Server Questions
SUPERMICRO COMPUTER Supermicro X8DTU-F Server Motherboard - Intel Chipset (MBDX8DTUF) Logo
325 people viewed this question
Top SUPERMICRO COMPUTER Computers & Internet Experts
David Payne
David Payne
Are you a SUPERMICRO COMPUTER Computer and Internet Expert? Answer questions, earn points and help others
