Question about HEWLETT-PACKARD Hewlett Packard Compaq 6005 Pro VS860UA Business PC - AMD Athlon II X2 215 2.7GHz, 4GB DDR3, 250GB HDD, DVDRW, NV... (VS860UAABA) PC Desktop
I currently have a amd athlon II x2 215 processor 2.7ghz. my computer started running slow the other day so i restarted it in which it started to beep and now gets as far as the compaq screen. i can only get on the bios setup utility thing but dont have a clue about that. if there is a solution for it would be appreciated as all files are on there. overwise any help on how to reformat and reboot the whole system again wuld be fine just to fix my pc!
    Problem Solver:
  • 19 Answers
The digital threds inside may have overheated or you computer has a no go virus is so do not power it up to prevent damage to the computer and take it to a professional computer tech don't send it to hp though that would be a huge bill
Posted on Apr 02, 2011
Upgrade processor
You have to now your motherboard.whithout that it is impossible to say.
Apr 06, 2013 | Dell Inspiron One 2305 Desktop Computer...
I just bought your AMD Athlon ll #x2 255 to replace replace my old one. I see in the instructions that I have a socket 754 and the new one is different. I/m trying to upgrade my computer. i also got y
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Roger Gross.
Yes your new AMD Athlon 2 X2 255 processor is made to fit both AM2+ or AM3 sockets.
Since your current socket is 754, you will need a new mainboard and DDR3 RAM to go with your new processor.
ASUS make very good mainboards. The ASUS M4A88TD-M EVO/USB3 mainboard is a good companion for your new processor. Install DDR3 1333MHz CL9 RAM from either Kingston or Corsair. 2X2GB modules should do nicely.
Feel free to contact me should you require additional assistance.
Take care!
Dec 22, 2011 | AMD Athlon II X2 255 ADX255OCGQBOX
Hi i purchased amd athlon x3 450 and only one core is showed in task manager,performance tab
Hi.
If your system is running XP then there is a file from Microsoft that you can download that may fix the problem. Remember once you have installed the fix you have to restart the computer for any changes to take effect.
Click on the link below for the download.
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=C2AB5A48-8240-4934-BBD8-34FB8A0FCE3B&displaylang=en
If your sysem is not XP and you are using Vista or Win 7 then don't download this fix as it will not work. Instead right click on Computer and select Properties from the sub menu. When the properties window comes up have a look at the processor under System and see if it shows how many cores the processor is currently showing.
Please let me know how you get on.
Good luck.
Jun 17, 2011 | AMD Athlon II X3 450 / 3.2 GHz processor
My new AMD Athlon II Quad 640 3g Crashes. It crashes almost once a day. All temps seem ok. the setup display says that it suffering fron power surge the cause. I have put a power surge device in the mains....
You might not have your voltage set properly in your bios and/or your power supply is either insufficient or going bad on you. Have someone test all the leads and be sure the voltage produced is as it should be. Also evaluate your system as a whole and compare the wattage -vs- the power supply you have. (i.e. running a powered vid card.. tv tuner.. two hard drives.. extra ram AND a beefy cpu on a 150watt supply is highly unlikely.)
Apr 12, 2011 | Advance AMD Athlon II X4 640 3 GHz...
I currently have a amd athlon II x2 215 processor 2.7ghz. my computer started running slow the other day so i restarted it in which it started to beep and now gets as far as the compaq screen. i can only...
You need to listen to and write down your beep code, ie;one long, one short, etc., It's more than likely a ram problem. If you have a manual for your system or know what version of bios you have, you can get the meaning of your code.If it's the ramand you have morethan one stick, you can test by taking one out and trying to restart then, try the other.
Apr 01, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
Hello. I have an embedded Ethernet driver, but it doesn't seem to work. When I plug in the cable, nothing happens. I can't find any software drivers on the internet for AMD Athlon II X3-450 .
If you are running windows vista or 7, go to computer right click go down to manage click on it. Then a screen will pop up. Go to device manager and go down to network adapters. Look for your ethernet controller and right click it and go to properties. Then click on the driver tab at the top. Go to the bottom where it says uninstall driver. Click on that and close everything out and restart your computer. Vista/7 will replace the driver with a default one upon restart. Hope this helps you.
Mar 12, 2011 | AMD Athlon II X3 450 / 3.2 GHz processor
The AMD xp1500 processor is slow. Its need to be faster than it is. Need to know. Cheers!
If your computer has less than 512MB of RAM, then that is one "bottle-neck" that hurts your computer's overall performance.
Consider adding 512MB or 1024MB of RAM.
Or, your motherboard probably will accept other AMD processors in the "Athlon XP" line. Take your computer to a computer-store, and see if they can sell you a '2600+' or '2800+' AMD CPU that will be compatible with your motherboard. That upgrade will make your CPU almost _twice_ its current speed.
Oct 22, 2010 | AMD Athlon XP 1500+ , 1.33 GHz Processor
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
Processor update..
The problem with Store bought PCs is that there is no way to tell how fast a proccessor you can safely put into one before it becomes overclocking, but in theory your exact motherboard should support an AMD Athlon X2 5800+ 1000 Mhz FSB. Now if your willing to take a risk, you could buy a 6400+ but be warned, the computer may not recognize it, or it may just underclock the proccessor, if the processor supports 800 Mhz FSB. I said the 1000 Mhz FSB because it can underclock to that speed, and also because they no longer offer 800 Mhz flavors at the sites i order from. Hope that helps.
May 01, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
HEWLETT-PACKARD Hewlett Packard Compaq 6005 Pro VS860UA Business PC - AMD Athlon II X2 215 2.7GHz, 4GB DDR3, 250GB HDD, DVDRW, NV... (VS860UAABA) PC Desktop Logo
89 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
