Acer aspire 3690 works ok but screen is completely black,currently connected to v.g.a monitor
    Brigadier General:
  • 6,966 Answers
Since the laptop works on an external monitor, then problem is restricted to the LCD display. The LCD display would be made up of 3 main components: the display itself, the backlight and the inverter.
Rarely do the LCD display panel itself go dead all of a sudden. At most would be initial discolorization or blobs or no display, or lines or garbage display.
Often it would either be the CCF lamps (least likely) that provide the backlight and more often, the inverter that provides the high frequency/high voltage supply of the lamps. Most encountered faults are dried up or blistered capacitors, some with swelling or burst marks at the top. They are readily available and need not be ordered from Acer. It would only require the part number since they are manufactured by a third party. Repairs and DIY (do-it-yourself) would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 05, 2008
Fix screen acer aspire notebook
try to boot press F8 choose use VGA
if successful install the old driver
Nov 17, 2017 | Acer Aspire 3690 Notebook
Very dull screen, will not brighten.
When you installed Windows 7, did you also install the drivers for the graphic card?
Jun 19, 2013 | Acer Aspire 3690 Notebook
Acer aspire 3690 the right half of my screen is black/white/lines
It sounds to me like your screen has gone and needs to be replaced
Apr 22, 2010 | Acer Aspire 3690 Notebook
Help... Acer Aspire 3690 laptop.
My dear friend as I told you that you should change your RAMs it will b ok give me your response on jazib_qurashi2000@yahoo.com
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
Computer is on, screen stays black
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
Wifi main wire, white or black?
White is Main
Black Aux, will work with out, but better to connect, so connector will not short out motherboard.
May 22, 2009 | Acer Aspire 3690 Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
