Question about Hyundai Computers & Internet
I'm having an issue with my Hyundai x90w LCD monitor. It powers on but shows no picture. The blue light turns to orange and it doesn't do anything after that. I took it apart and can't find anything wrong with the capacitors.....and that's where I'm at.
SOURCE: AL 1716 LCD monitor has no power when plugged in.
As someone suggested the 3 10 volt 1000uF caps are bad. You can indentify them because they're puffed up on the top and therefore blown. Replace them withj a 25 volt cap 470uF or larger and away you go. I did 4 of them in 3 hours. The case snaps apart which is the hardest part. them remove all the screws you can find, unplug the display from the board, remove the rest of the screws holding the power supply board down, and look for the puffy caps. Cahnge them and put everything back together and away you go.
Richard
Posted on Jul 21, 2008
SOURCE: Monitor will not stay on
check your driver to ensure that it's the correct driver.
If the Hz is not correct for the monitor... the monitor may turn itself off.. :0)
Posted on Aug 06, 2008
Fix-4U
  • 293 Answers
SOURCE: lcd display mainly just white
Hi...Brye,
Well... you've fixed the inverter problems, but another problems has pop-up...It's seems you probably burnt out the chipset that contains the bios. That's why the screen turned white... cuz no information in the bios. You'll need to updated the bios or just replaced a new AD Board. Have fun...Good lucks!
Posted on Sep 14, 2008
noone
  • 105 Answers
SOURCE: LCD Monitor is black... blowing transistors
Bulging or "blown" electrolytic capacitors are a common problem with LCD monitors. If you replaced them with correct parts (voltage rating) then one of two situations comes to mind:
1. Electrolytic caps are polarized, if you install them backwards they will blow quickly.
2. The voltage the circuit provides exceeds the rating of the cap. A 5 volt cap in a 12 volt circuit will blow quickly. The voltage regulation circuit may not be working.
Monitor Mike
Posted on Oct 02, 2008
When i switch on my pc the monitor display a blue power light for 5 seconds and then it turns to orange and nothing displays on screen.
Make sure you have connected the Video cable properly, Please disconnect the Video cable from the Computer and connect the monitor only to the power source. If you monitor shows anything like "Check video cable" or "No Signal" that means the monitor is working fine. You just need to connect it properly to the computer
For any further assistance feel free to get back with your comments .
Thank you for choosing Fixya
Nov 01, 2010 | Acer V193w LCD Monitor
Monitor no longer works - all black
there is no reset button on lcd monitors, check power cable first, if the blue pilot led lights but no picture, you might need to bring the unit to the shop for servicing..
May 09, 2010 | Samsung SyncMaster 245BW Monitor
My biewsonic va702b, when powered up flashes for one second the screen. it's bright in all the corners, just wont stay on, power light changed to orange. do I have inverter problems??
The power light turning orange means the monitor isn't getting a signal from the computer. Or the monitor has a problem. If the screen shows light in the corners, the inverter is working. (If the inverter stops there is no light at all.)
The first thing to try is connecting another monitor to make sure your computer is actually starting up. If that monitor also shows nothing, you have a computer issue to take care of. Otherwise the monitor needs service.
Mar 03, 2009 | ViewSonic VA702B 17" LCD
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
L90D+ will no longer work
The video card is gone ,to expensive to fix it.
Jan 03, 2008 | Hyundai L90D+ 19" LCD Monitor
Computers & Internet Logo
223 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
