Question about Toshiba Satellite A55-S1063 Notebook
My lcd screen flickers and then go's black. - Toshiba Satellite A55-S1063 Notebook
  • 368 Answers
Glad to HELP YOU!
I'd say it's a problem with your VIDEO CARD.
The video card could have a break or a short that could result in a poor/bad signal being sent to your display. The extra load on it (in sending information to the monitor) could have been generated a malfunction of the card.
Try to make up-to-date the driver if possible. To do so connect to your machine another monitor (through cable, of course) and see if you can have "image" there. If yes, then go for the update!
To do so go
right-click on MY COMPUTER > PROPERTIES > HARDWARE > DEVICE MANAGER
and there select VIDEO CARD (or whatever is called) from the list of devices.
Right-click on VIDEO CARD > PROPERTIES > UPDATE DRIVER
After the update was done REBOOT.
Posted on Apr 01, 2011
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Laptop screen flickering
The video inverter may be failing, BUT...
More than likely the backlight is failing. If you can still see a VERY faint image on the screen this is almost certainly the problem.This is a very difficult fix. I recommend a replacement LCD.
It MIGHT be a bad lcd cable. With the laptop on, slowly open it from closed to open and back again and see if there is a position where the laptop screen does not flicker or turn off, [or if it does turn off if it turns back on.
If the screen goes COMPLETELY black then your GPU is failing.
Feb 21, 2012 | HP Computers & Internet
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
After turnoing on my sl500 the screen flickers and turns black
Check your video adapter settings. try to set it on clone and see if the picture would appear the same on your LCD. From there you select it back to your LCD. Just make sure the primary display is set to your LCD and apply the changes.
Hope this helps.
Dec 20, 2009 | Lenovo ThinkPad SL500 - Intel Core 2 Duo...
Laptop screen flickering in hp laptop. had it for 1 year. screen stays on but flickers black very quickly
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 05, 2009 | HP Computers & Internet
Hanns-G HG216D is flickering to black screen
Started working after I d/l the driver
http://cms.hannsg.net/onweb.jsp?prod_no=3333333617&webno=33333333:0
Jul 31, 2009 | Computers & Internet
Black screen/flickering
try using an external monitor, if the problem doesn't happen on the external monitor then definitely the problem is with the LCD screen. Possible replacement required for the LCD panel.
Jul 13, 2009 | Compaq Presario CQ50-215NR Notebook
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Dec 04, 2008 | Computers & Internet
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Toshiba Satellite A55-S1063 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
