Question about Hoover Washing Machines
Wont drain water ,and wont spin model hoover 800rla maybe 4 years old? cheers frankm
    President:
  • 1,462 Answers
Have you checked filter and also check for foreign objects in pump impellor - that is the usual problem.
if both of these ok, then check continuity thro the pump windings
Posted on Aug 05, 2008
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
It spins, but doesn't pump
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
It doesn't spin or pump
frozen pulley pump replace
It pumps, but the water returns
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Kemore washer will not spin
Is your drain pump blocked?
The machine will not spin until the water is drained.
Some models have a small door at the front bottom of the machine. Open the door and unscrew the coin trap. There maybe some debris in there?
Also check the end of the drain hose where the water comes out. Sometimes the foreign material goes through and blocks at the end there.
Hope this helps!?
Jun 19, 2009 | Washing Machines
Hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Nov 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Mar 05, 2008 | GE WDSR2080D Top Load Washer
Wont spin
Well yes it could be.... and on a hoover usually is..
but could also be that machine is not draining properley and there fore the pressure switch which affects the final spin is not allowing the machine to spin thinking that there is still water in the machine....
hope this helps any questions dont hesitate to ask...cheers
Jan 09, 2008 | Washing Machines
Washing Machines Logo
132 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
